Question about Canon XH A1 Mini DV Digital Camcorder
Canon XH A1 needs a new LANC connector. Is it in/out module?
SOURCE: Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Posted on Dec 04, 2007
vac8
  • 15 Answers
SOURCE: Getting poor quality uploads to my pc from my Canon XH-A1
You need to upgrade you ingest system. Windows Media Player(and your system card) probably can't handle the load. Try "Scenalyzer" it's economical, versatile and stable( http://scenalyzer.com/).
Posted on Jan 14, 2009
SOURCE: My Canon XH A1 will not turn on to record
I can confirm that it was in fact the standby/lock lever. Toggling the lever to standby fixed the issue.
Posted on Dec 10, 2009
  • 22 Answers
SOURCE: XH-A1 Non Recogition
I occassionally have this issue, what you need to do is set the camera playing BEFORE you connect and load up the software. This should then show an image in the import settings in iMovie or whatever you are using. If you are using iMovie, do a manual import and rewind the tape on the camera manually with the import just running. When I do this it usually solves the problem for a while but every now and then it'll arise again, usually when switching between using HD MiniDV tapes and the standard ones and hence switching between SD and HD recording on the camera, seems to confuse it somewhat...
Posted on Jan 21, 2010
etaf
  • 779 Answers
SOURCE: need owner;s manual
The manual is available from this link, along with other downloads - drivers etc http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=369&modelid=14061
Direct link to the PDF Instruction manual http://gdlp01.c-wss.com/gds/5/0900000685/02/XHG1_A1NIM-EN.pdf
Direct link to the console guide http://downloads.canon.com/cpr/software/video/CONSOLE_V1-1_ENG.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Apr 03, 2010
How can I transfer my recordings
Hi Greg, you need to provide more information, for instance , from what medium to what medium, (media types.) Please add the detail and resubmit
Jun 02, 2015 | Canon XH-A1 High Definition Mini DV...
Canon Xh a1 won't turn on, HDV and Power are blinking
It could be the blown fuse that located on the main circuit board.
Dec 18, 2014 | Canon XH A1 Mini DV Digital Camcorder
Xh 1s capturing video
Jack you posted in the wrong category. If you post in Canon video you'll have better luck or try the DVX User forums for that model:
http://www.dvxuser.com/V6/forumdisplay.php?93-XH-G1-and-XH-A1
Mar 17, 2014 | Canon Cameras
Why won't my Canon XH A1 power up
The most likely cause is a component failure in the power circuit. This can be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be looked at by a qualified technician. Here is a link to a repair shop that should be able to help you.
www.discountcamerarepair.com
Nov 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
Need owner;s manual
Apr 03, 2010 | Canon XH A1 Mini DV Digital Camcorder
Jan 14, 2009 | Canon XH A1 Mini DV Digital Camcorder
Its a canon XH-A1
Please go to Display setup > TV Screen display > OFF
very simple procedure.
Dec 20, 2008 | Canon XH A1 Mini DV Digital Camcorder
My Canon XH A1 will not turn on to record but the camera will turn on to watch playback. I need help!!!
Check your little lock and standby lever at the back of your hand strap, its likely positioned between standby and lock.
Dec 01, 2008 | Canon XH A1 Mini DV Digital Camcorder
Canon XH A1 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
