GATEWAY ta6 WAS DROPPED ON THE CONNECTION FOR THE EXTERNAL POWER SUPPLY (ac adaptar) AND IT MADE THE PIN LOOSE ON THE LAPTOP. I WOULD LIKE TO TAKE THE COVER OFF AND REPAIR THE PRINTED CIRCUIT BOARD AND PIN CONNECTION(INTERNAL CONNECTION). ANOTHER MODEL NUMBER ON THE COMPUTER IS CX2720. THANKS
    Problem Solver:
  • 6 Answers
Try here - detailed photos for same problem on different model Gateway:
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
Posted on Apr 25, 2009
    Problem Solver:
  • 7 Answers
If you are going to pull the laptop apart, I suggest replacing the plug entirely. Here is a link to purchase the power connector. http://cgi.ebay.com/OEM-DC-POWER-JACK-CONNECTOR-SOCKET-GATEWAY-CX2720_W0QQitemZ120338596034QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
I have repaired many laptop power connectors. I've never used a service manual. It take a little patience, and determination. Just start pulling out screws and feeling around for clips. You'll eventually get it. Just think, all these laptops were put together with the intention of being able to pull them apart, whether it be in the field or at a repair facility. "You Can DO IT!"
Posted on Dec 11, 2008
Gateway nv59c shuts off when picked up
On battery or AC? I would suspect a loose connection, AC cord, AC jack. Has it been damaged, dropped, banged, jarred, etc. Obviously something is loose/broken causing intermittent loss in the power circuit. If you have a multimeter you can troubleshoot the issue from AC outlet to AC jack, then you have to open the laptop or take it to a qualified computer tech. Is the laptop under warranty? If so Get in touch with Gateway at once, to repair/replace. Don't delay.
Nov 19, 2012 | Computers & Internet
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
When you move the computer working under external
issue with the ac jack. It has a loose connection. you will need to open up the laptop and remove the board to re-solder the AC jack.
Jun 02, 2010 | Acer Aspire 3000 Notebook
My Gateway laptop use AC cord with the output 19v = 3.42A. can I use the AC cord with the output 19v = 3.95A?
Yes you can use one that has an higher current rating. The system will only use what it needs. If you try to use one with an lower current rating the power supply would fail. Just check to make sure the pin out is the same..ie postive tip or negtive tip.
Feb 23, 2010 | Gateway HQRP Replacement Laptop AC Adapter...
Dell precision m50 will not boot power light just flashes when I push the power on button. I have reseated all of the connection in the laptop. I have tried different batteries and different power...
remove external peripherals. remove battery. use ac adapter alone. check if ac adapter has sufficient power or check if ac adapter led is solid green or blue. if not then ac adapter might not giving laptop enough power to power up.
if ac adapter led stays on but some problem check the ac adapter - laptop pin socket if loose or damage. if not then replace mobo.
Dec 07, 2009 | Dell Precision M50 Notebook
My laptop doesn't boot up. Only get a black screen.
have you tried connecting to an external monitor?
Oct 15, 2009 | Gateway M285-E Notebook
Dropped my gateway laptop. Now it wont charge battery.
If you do not have either a manufacturer warranty or extended warranty from the retailer use it now. Contact them. Avoid telling them that you dropped the computer...you will void a manufacturer warranty. If you don't have either option then you can continue portability with an external laptop battery. They tend to be heavy, but they tend to provide 5 or more hours of portable use. The extended battery plugs into the same socket as your regular external power supply. I have included some links for product options.
http://www.youtube.com/watch?v=q1om-j6AGNg
http://reviews.cnet.com/1990-3121_7-5127099-1.html
http://www.batterygeek.net/Portable_Power_Stations_s/38.htm
http://www.amazon.com/s/ref=nb_ss_gw_0_13?url=search-alias%3Daps&field-keywords=external+laptop+battery&sprefix=external+lapt
Good luck
Jan 19, 2009 | Gateway 450ROG Notebook
The power on my laptop won't stay on
The jack or AC power pin can be fixed yourself if you're up to it. The part is usually under $10. I've done three (2 Fujitsu' and a Sony. Take your time when you take it apart and take pictures of the disassembly. They will com in very handy when you start to put it all back together again. When you get it fixed invest in a proper cable retention device so the AC power pin doesn't get damaged again. This short Chris Pirillo Video talks about CRDs on laptops.
May 26, 2008 | Gateway Solo 5300 Notebook
Computers & Internet Logo
934 people viewed this question
David Payne
David Payne
