Question about RCA Televison & Video
My television turned off for no known reason and it will not turn back on. Please help.
  • 20 Answers
You may need to replace your Tvs convergence board. Go to www.partstore.com and type in your Tv model #. It is a simple swap procedure with no soldering. It costs about $80 or more. It takes 30 to 45 minutes to replace.
Posted on Dec 11, 2008
What causes my picture to go pink all of the sudden ?
Examine the screen with set on and color set to zero--stand back and look= is screen pink to red color?
If so it may be a common issue on this Hitachi.
Usually it is an adjustment inside the set of the red screen control needing to be turned just slightly down---these are known for the red control "drifting" just slightly from time to time--answer is based on model number indicated here.
May 31, 2012 | Hitachi 46F510 46" Projection HDTV
Mitsubishi WS-48311 projection model. It started turning off for no reason and I would turn it back on while watching a program. Then it went off and will on come back on. Then you press the power button...
gtl545,
This model has a known defect. The power supply board and DM boards have failed electrolytic capacitors. No spares are available from the factory. Fortunately there are after market repair kits available. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem as well as where to get parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 26, 2011 | Mitsubishi WS-48311 48" Rear Projection...
Lately, my RCA HDTV monitor has been shutting off
Probably bad capacitors on the power supply board. There are about four that should be replaced all at once. The to of the capacitors will be "puckered" or bulged out. They are located toward the front of the power supply.
Oct 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv shuts off for awhile then i can turn it back on immediately
hitachi is known for its problems and the best solution is to call a repairman out to repair it properly.i know thats not much help but its the only sure way to fix it and fix it right
Jan 21, 2009 | Televison & Video
My tv wont turn on??!!
there are six capacitors on the DM board 1000uF 16 v that go bad, repace them with 680uF 16 v. 105C. the capacitors are clustered together. on the DM board the DM board is the board that is enclosed in the metal box. the repair is not an easy one so have a tech help you. this is a known problem.
Jan 04, 2009 | Mitsubishi WS-48613 48" Rear Projection...
My nice HDTV want turn on. Please help!!!
The itc222 chasis from rca is known for this. The processor shuts down the set for any number of about 25 reasons. As a customer the first thing you do is unplug the set for about 30 min to reset the processor. ( I have never seen this work but it is the first step. The conclusion that you also can draw is the main fuse is okay. This set can be read by a technician with a computer to learn error codes generated by processor. But this is where the troubleshooting begins.
Feb 11, 2008 | RCA HD52W59 HDTV Projection Television
NEW TV WONT TURN BACK ON
polorid known for going out take it back asap those have worse revies back panel go out ok no good please upgrade yourself to a nice samsung or sharp ok for best quilty for yrs to come u be happpy u did
Jan 29, 2008 | Televison & Video
Samsung HLN617W 61 in
Get on the phone to Samsung at1-800-522-7341.
You have one of the dreaded N series that is full of problems.
Even if you are out of warranty, they have been known to work with you.
Dec 22, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Viewsonic w3250n no sound, no picture, beeping
Hi, Any other indicators aside from the beeping sound like blinking leds/lights? For the time being try to do a hard reset, unplug the LCD TV from the mains for a couple of hours and thereafter try again with a known good outlet.. If still a no go, post back, Good luck and kind regards.
Aug 26, 2007 | ViewSonic NextVision N3200w 32 in....
Won't turn off
Unplug the unit from the wall not just to turn it off but to see if it resets and goes back to normal.Plugn it back in after 5-10 minutes.Good thing for you is new.
Oct 03, 2006 | Fujitsu PlasmaVision P50XHA40US 50 in....
Televison & Video Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
