Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer 90 series Washer will not spin
My kenmore 90 series washer will not spin. It makes all of the sounds, but the tub will not spin.
  • 6 more comments
  • shaemarie Dec 23, 2008
    Same thing. Washer tub will not spin during rinse cycle.
  • spinnot Dec 23, 2008
    will not spin make all the sounds but will not spin
  • unclehealer Jan 31, 2009
    When you put the washer on spin all it does is hum, no movement just a hum.
    my washer just hums on the spin cycle no movement just a hum. I replaced the motor coupling but it still does not work
  • francesvega6 Feb 06, 2009
    my kenmore washer 80 series lets the water out but the tub is not spinning could you please show me what is wrong with it
  • heathfamily5 Feb 25, 2009
    Water empties but does not spin. I can manually turn the knob to spin once the cycle has ended. It will then spin OK.
  • Anonymous May 07, 2009
    motor hums but does not drain
  • unclehealer May 11, 2010
    How do I reset the Brake?
    President:
  • 373 Answers
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Posted on Dec 11, 2008
    Problem Solver:
  • 12 Answers
Depending on your model it could be the motor coupling or a belt. If either one has been changed and it still does not spin but the motor still hums. Check the break. Sometimes when a motor coupling or a belt breaks the washer tub can **** and hit the break lever. Once that is reset it should work.
Posted on Jan 31, 2009
2 Suggested Answers
  • 1937 Answers
SOURCE: My Kenmore 90 series washer motor runs but the tub does not move
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Mar 26, 2010
Kenmore 90 series washer. As the tub tries to
It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
Apr 15, 2010 | Kenmore Washing Machines
My kenmore 90 series model 110 will not spin, makes a buzzing sound
HI,
This problem is caused by either a broken washer tub drive belt or a broken washer tub drive coupler, look under the machine for evidence of this.If it is found to be true you have to go for a replacement of that particular unit.
Mar 29, 2010 | Kenmore 24032\24036 Top Load Washer
90 series Kenmore washer won't spin
I have had this happen on a Kenmore in the past, and it was the motor coupling. It is a plastic part, and if it cracks your washer will not spin anymore. If you have the repair parts list, or can find it online, you will find the part I am referring to. Good luck.
Jun 03, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore washer 90 series wont spin
If your trans and coupler are good then I would suspect the drive block or spin tube. You will have to remove the trans to change out the spin tube. Take out the basket, there should be 2 ears from the spin tube that nest in the drive block. Attached is a photo to help you understand. Before all this make sure nothing is caught between the basket and the tub. Catriverd8086fb.jpg
Nov 26, 2007 | Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,754 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
