Question about Furuno GP32 GPS Receiver
Connecting furuno gp32 nto laptop
I am having a problem connecting the gps to laptop I have connect it through a usb to nine pin serial plug lead and hav einstalled the drivers .
But the signal dosnt come through on the chart program but the program starts kumping the cuser jumps all over the place it may need some setting changed .
Any help would be very much appreciated.
Cheers kevim
You need to connect the gps after your laptop is going this should stop it thinking that the gps is a mouse
Cheers
Jan
Posted on Feb 07, 2011
Always turn on the laptop first then after a couple of minutes the gps.
Posted on Dec 15, 2009
This is a problem in Windows where NMEA data is interpreted by the computer as serial mouse inputs. There are various fixes. If you type Windows mininsterpret NMEA serial mouse into Google you will find lots of info.
Posted on Jan 22, 2009
I have an gps furuno gp32 and in the setting the user display is off. when i switch-on the screen is bloqued. please how to reset the gps gp32 thank you
This information is not in the GPS instructions.
To reset the GPS, you must click on the arrow UP and together on Power.
The display shows that the system is reset.
Then, the GPS is working properly
Sep 09, 2011 | Furuno GP32 GPS Receiver
Does my furuno GP32 have an internal antenna or do I need the to install the extra one?
Hi!
Your Furuno Does NOT have an internal antenna. You have no choice but to install the external one.
Hope this helps.
Jan 27, 2011 | Furuno GP32 GPS Receiver
Connection to PC for Nav software
Assuming you have GPS input to your 1732 (i.e. GP310/320 sensor), you'll need a 7 pin NMEA data cable (000-154-028) wired to a D-sub 9 pin (serial) plug. The shield goes to pin 5, blue to #3, & white to #2. Jumper pins 7 & 8 together. The 7 pin cable goes to Data port 3 of the 1732.
Jul 12, 2010 | Furuno Navnet 1732 GPS Receiver
I want to know where the red,yellow,blue, green,,white,and black wires go?
red and black are power and ground, blue and white are gps output signal connect those to 9 pin connector pins 2 and 5 and get a 9 pin(serial) cable to usb adapter for input to a laptop, charting or mapping program and you are good to go. just make sure if you are using xp to wait until the mapping program is running and searching for gps signal before you connect the serial or usb because windows thinks the signal is from a mouse and the cursor will turn into a raging crackhead jumping all over the screen and randomly clicking on whatever it touches.
Jun 17, 2010 | Furuno GP31 GPS Receiver
To connect gps to computer wich pins do i connect of nmea cable?
pins 2(-) and 5(+) on a 9 pin serial cable, then you need a usb to serial adapter for input into the computer if you do not have a built in 9 pin serial port on you computer because the usb moves the information faster than the gps signal. gps is roughly 4800 baud, usb is moving so much faster you need a buffer
May 19, 2010 | Furuno GP32 GPS Receiver
How to interface a furuno 1833c navnet to a usb port and how to download waypoints to my pc.I have the older 9 pin pc cable and a usb adapter cable.Looking for usb drivers and software to make it work.
The display uses a serial interface, otherwise known as a comm port. You can get a USB to DB9 adaptor practically anywhere. Once you have a serial connection, you will need software such as MaxSea to send the waypoint with.
Jan 11, 2010 | Furuno 1833C/NT GPS Receiver
Wiring
use the yellow and green check for pulsing voltage on wires with digital meter measuring 12V you must turn on the data in the Furuno menus
Mar 07, 2008 | Furuno GP32 GPS Receiver
Furuno GP32 GPS Receiver Logo
1,755 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
