Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Blue haze image
We love our tv until about 6 mos ago the lamp went out and we replaced it. About 2 months later our tv developed this blue hazey image at the bottom of the screen that is now continue to spread upward towards the middle of the screen. We called Sony for advice but ended up with little to no help at all. I'm at wits end, any solution or suggestion is greatly appreciated.
  • TRABakers Dec 29, 2008
    We have the same problem. We have had our tv for 4yrs and just changed the bulb. We now have a blue blob that started right side of the tv and has been spreading and the image is horrible. We hope to fix the problem and are looking for a solution. Any help is great!!
  • tmsmith76 Dec 31, 2008
    We have a blue hazy image at the bottom right as well. We've had it for about three years and it just appeared suddenly. Hope it's a cheap fix!
  • 320 Answers
You have a bad optical block. there are companies that rebuild optical blocks for a nominal charge. Check out:
http://www.tristatemodule.com/index.html
Posted on Dec 21, 2008
I changed the bulbs in my two projectors awhile back and a month or so later they both started getting a blue dot/haze that has progressively gotten worse...any ideas?
service is very important be four replacement of lamp if you have a Multi color background in your image then your projector just need service of LCDs and inner parts of projector.
Jan 18, 2011 | Panasonic PT-LB20U Multimedia Projector
Little blue dots on screen and large blue haze in upper left corn
Sounds like the light engine is going bad...that's why they stopped making these rear projection sets using LCD's. Costs almost as much as a new set! But get a second opinion before trashing it.
Apr 15, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
My zenith D52WLCD has a blue haze going diagonally
This a Normal Intensive Use Defects, this a Screen Burnout. Sorry
Oct 31, 2009 | Zenith Televison & Video
Blue Haze in middle of screen progressively getting larger
This one is easy. WHen this happened to me, I simply called GE extended warranty service up and bought an extended warranty. I waited 30 days and called them up with my problem. A repair man showed up a few days later with the 1200 dollar light engine and installed it and left. Then I called GE up and cancelled the warranty. Total cost?: 48 bucks
May 30, 2009 | Hitachi 50V720 Television
Blue haze on tv picture
I had the same problem with mine..it was the circuit board. Good thing I had warranty. It was over $800
Mar 28, 2009 | Hitachi 51F59 51" HDTV Projection...
Yellow and blue on screen
I am slightly confused about the model of the television, because a 46F500 is a rear projection set that doesn't have a lamp. It has 3 picture tubes and I have a few of them in my shop right now that have the problem you reported. What we do to this set when it develops a convergence issue is to check each resistor around the convergence chips for discoloration, and replace any of them that have changed in value, along with the STK392-150 ic's. If you don't have an ohm meter and solder/desolder equiptment, you can usually get a shop to do this repair for 150.00 to 350.00. Parts will be 50.00 and labor , the rest, depending on the quality of repair shop that you use. Good luck, Russmann.
Nov 16, 2008 | Hitachi 46F500 46" Rear Projection...
Blue Haze
yeah I have the blue haze also whats up?
May 20, 2008 | Hitachi 50V720 Television
Blue haze
REPLACE LIGHT ENGINE,
May 12, 2008 | Hitachi 50V720 Television
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
245 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
