Question about Kenmore 98702 Stacked Washer/Dryer
Washer will not fill with water
I am not a technician but have experience with general electrical circuits. I had finished washing one load of clothes, no problem. Then as I prepped the next load...no water. The spin cycle worked fine but I did not hear the water valve solenoid engage to open, allowing water into the machine. Recently I had the control panel off while fixing the dryer door light switch (do not forget to de-energize before accessing!). What I found when I took this panel off again was a wire (washing machine side) that had shorted against the chassis! So, when you remove the control panel ensure you support it to prevent over stressing the wires it dangles from in this condition.
    Problem Solver:
  • 16 Answers
Sounds like the water solenoid has gone open-circuit. Tom.
Posted on Mar 09, 2007
E11 error code
Good Morning Juan, thank you for allowing me to assist you!
Generally, error code E11 indicates that your washing machine is taking a long time to fill (or is continuing to fill).
    ·Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from your washing machine. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
    ·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
    ·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Jan 16, 2014 | Frigidaire ATF6000ES Front Load Washer
When finish washing clothes in front loader, all my cloth are hot is tha normal?
check the the fill hoses on the water valve are not reversed. cold to cold and hot to hot.
Feb 09, 2011 | General Electric WBVH5100HWW Front Load...
No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
Jul 27, 2010 | General Electric WBVH5200J Front Load...
Wont fill with water? work 4 2yrs
first you have to check the valve in the back of the machine sometimes people that are on well water get deposits that build up on the inside 2nd you would have to check to see if you have power going to both sides of the valve . you do this by removing the entire washer cover. If you do not have electrical experience in testing for voltage please call a technician the valve is what brings the water into your unit
Apr 28, 2010 | Roper RAX4233PQ Top Load Washer
Cold water does not fill for the wash cycle but will fill for the rinse cycle
just a guess make sure hot water line goes to hot water inlet look close there is a difference and cold to cold cold will be blue
Apr 12, 2010 | General Electric WHDSR316G Top Load Washer
Washer will not fill up with water. but it will during rinse cycle
are u washing in hot
try filling with cold
did it work
if yes your problem is your hotwater solonoid either bad or stuck or clogged
Oct 09, 2009 | General Electric WBVH5200J Front Load...
Washer fill with water after the cycle is over
well ,either the machine wasnt finished (it may have been doing a second rinse and spin) or the electric valve not shuting. try let it fill and see what happens
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
