Question about Air Tools & Compressors
I have a porter cable FN250a nail gun, i lost my manual! I would like to know how to adjust for 2 1/2" nails?
    President:
  • 1,388 Answers
Http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En%20903908.pdf This the manual for fn250b, newer version of the gun that you have. Hope this helps.
Posted on Dec 11, 2008
How do I release the trigger lock on a brand new porter cable nail gun
Are you depressing the nose of the nail gun against the material to be nailed first? Without doing this, the trigger will not "unlock". You can read a pretty in-depth review of this nail gun at OnlineToolReviews com Porter Cable FR350A Full Round Head Framing... which might also help.
Jul 16, 2014 | Porter Cable FR350A Factory Reconditioned...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
16 ga nails dont set flush to wood.
Assuming that the nail head not setting in and adjusting depth control does not remedy. Usually occurs when the tip breaks off. Remove the head and pull out the driver to examine tip. If tip broken or bent, replace with new or try to adjust as needed. If about 1/16 of tip broken, reshape the driver so that the tip is just slightly wider than nail head, taper the lower 1/4 inch on the side of the driver that faces the nails so that the driver will only strike one nail and reduce (shave) the size of the lower bumper so that the driver will extend out same amount that you need due to broken tip(only works if 1/16 -1/8 broke off).
Nov 16, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
How do I load the 2 1/2 inches nails to my 16 ga porter cable finish nailer? How do I put the oil and what part of the gun?
You need to open the nail magazine and you just load one strip of nails at a time, then close the magazine. It will have a spring putting pressure on the nails, so it will have resistance on it and it will increase as you close it.
The oil gets dripped in the air hose connection on the gun before you connect the air. Make sure that this gun actually takes oil, some newer guns are oilless.
Hope this helps,Matt
Dec 10, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
Driver pin on model FN250A not retracting far enough to drive next nail. Will shoot 2 or 3 nails and miss 6 or so.
I had the same problem with an electric stapler from Craftsman after years of disuse. The solenoid that powers the hammer that is no retracting may require lubing if this is possible.
If not, then if the product is within warranty, you might be able to get a replacement.
Jul 04, 2010 | Porter Cable Air Tools & Compressors
Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Jan 23, 2010 | Porter Cable Air Tools & Compressors
I just bought a porter cable fr350a nail gun and need to know what type and angle nail goes in it.
it will shoot a nail from .113 to .148 diameter plastic collated full round head from 2" to 3 1/2" 22degree nail. If you want you can download the instruction manual from Dewaltservicenet.com and type in your model number under looking for manual it is 15 pages long. If I have helped you with your request would you please rate this response accordingly and thank you.
Nov 12, 2009 | Porter Cable Cable No. FR350A Rnd Head...
How to remove a jammed nail in a porter cable fr350 nail gun
Here is a link to the manual for your nail gun. Refer to page 11 of the manual for removing a jammed nail. To get the manual, go to the link, click on the "Manual" tab and the in the gray box, click on the name "FR350A Manual". The link is:
http://www.tylertool.com/porfrrounhea.html
Hope this helps. If it does, please leave feedback.
Oct 08, 2009 | Porter Cable FR350A Factory Reconditioned...
Air Tools & Compressors Logo
337 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
