Question about Philips 55PP9401 55" Rear Projection Television
60pp9202/17f color problem
I have a philips model 60pp9202/17f and i need help with the color it looks like there is three picuters of the one and they are red, green , blue . it was built july 2004
  • jessie69mva Dec 11, 2008
    i have a philips model 60pp9202/17f and i need help with the color it looks like there is three picuters of the one and they are red, green , blue
  • Philips Master
  • 3,459 Answers
Common problem. Your convergence chips and resistors need to be replaced. Check with the site www.TvRepairKits.com for parts and replacement instructions.
Posted on Dec 12, 2008
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
Sony Grand Wega KF-E50A10 looks like it is 3D and we can't adjust the convergence through the screen settings, what should we look at next? Red is the color not lined up, blue and green seem fine.
Most likely if you cant adjust the convergence then the convergence IC's are in need of replacement. Does the picute look like the one below? if so then these chips need replaced. dcramer531_120.jpgdcramer531_121.jpg
Jul 05, 2011 | Sony Televison & Video
The colors look very weak. The green is weaker than the blue. Red seems ok. I have a philips 60 inch rear projection. It almost looks like a haze. The colors are not crisp. .
The TV has coolant in the CRTs that after years of use get cloudy. you will need to have a shop replace the coolant in all three, it is pretty involved so its best to have a trained tech. do it.
Oct 30, 2010 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6040CI ? Alignment ?
you have to set up the convergence using the on screen pattern generator.
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture is doubled and multi-color
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 20, 2009 | Philips 55PP9363 55" Rear Projection...
Half display on plasma
How close is hi power stereo speakers or anything with magnetic
Apr 21, 2017 | Philips Televison & Video
I have a toshiba model 50h72 double vishion
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 12, 2008 | Toshiba 50H72 50" Rear Projection...
Colors distorted
u need to check the convergence ic first most of the time that is what is wroung with it and if u replace them yourself make shure u use heat sink grease on them or they will go out with in a month or so
Jul 23, 2008 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
376 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
