Airconditioner has weak cooling power.
I have a split system airconditioner in an average size bedroom, it has a limited abiity to cool the room. For example the normal room temp is usually about 32 deg C and the unit is only able to bring the temp down to around 27-28 degC. When I checked the unit on the outside of the house the compressor fan was running fine in comparison to other units we have in the house but, the lower hose and brass fitting on the right side of the unit was extremely cold and covered in ice. On the other units it gets cold but moisture only condenses on it. Also the metal fins behind the dust filter on the indoors section become covered in ice.
Any advice you could give me would be mucch appreciated as the trouble shooting guide at the back of the instructions was of no assistance.
  • david_edgar7 Dec 11, 2008
    Thanks for the help. Time to get a repairer in I think. :-(
  • 96 Answers
If all the coils on the out side and inside units are clean and the fan motors are running fine it sounds like it could be low on freon
Posted on Dec 11, 2008
What is the difference between a ducted and non ducted Domestic Air Conditioner?
Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
Aug 05, 2017 | Heating & Cooling
Related to cooling
Sounds like you have poor insulation in that room or the unit is undersized for the room it is cooling. It should not get hot quickly is there is good insulation and is big enough to do the job. Since you do not mention the age of your home/room or the size of the room, I can't be more specific. The number of turns may or may not be an issue. Depends of which of the lines are taking all the turns. Are the lines insulated? If they are overly long this could take longer to cool down but not much else if the system in full of Freon. If you do not feel cold air coming out of the unit at all and the compressor is running then check the air filter. If it is the littlest bit dirty and the unit is undersized for the room then any restriction would make it even more ineffective.
Apr 20, 2014 | LG LSC121PMA Split System Air Conditioner
I need one split ac for my bedroom. i use ac for 5 hours a day. shpould i buy a 5 start rated panasonic ac for Rs 28000 or a 2 start panasonic ac for rs 18,000. how much electricity i will save in a year
A more relevant question is what size Ac do you need to do the job correctly. A unit too small will run too long, consume more power and not cool the house effectively, so in my opinion a complete waste of money. I suggest that you ask a local contractor or equipment supplier for a equipment sizing guide. If that is not available, perhaps obtain a number of quotes for the area that you wish to air-condition and then take an average sizing from those quotes. regards Col R
Mar 03, 2011 | Heating & Cooling
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
How to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Mar 24, 2010 | Heating & Cooling
Anybody there?
It depends on the room varables, If it has an attic, tile ceiling, what type of walls, where in the building is the room and so on? The biggest problems is all ways the power. Get a free estaimate from an A/C company. Everyone and myself needs to see the room before they give you an recomndation that can truly be applyed to your situation. But to give you some ideas, I would put a 2.5 ton - 3 ton unit just for over kill. Go with a straight cool package unit. If your company tight on cash just get a mini split system with a 30,000 BTU to 36,000 BTU cooling capacity. Cost for something thats going to last 20 years, avg. is $4,500- for the package unit and as low as $3,000 for the mini split.
Oct 17, 2009 | Frigidaire FAA055N7A 5200 BTU Room Air...
2002 Buick LeSabre Limited. Airconditioner cools
The dual air on this car has two temp control motors that are electronic. You need to have the car scaned at a dealer to see if it has a code for the left temp feed back circuit. If so you will need to replace the temp control motor for that side.Good Luck
Apr 30, 2009 | 2002 Buick LeSabre
Heating & Cooling Logo
162 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
