Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Sony pfm42b2 plasma tv
Hello, I am having a problem with the display flickering on start up. Kind of like a vertical hold problem on the old sets. The colors seem to change until the set is warmed up. It seems to be taking longer and longer for this problem to clear.About 15 minutes. It is more than likely a board problem?? I was told that any one of the boards cost was about 500.00 or more. Because it is an older set i didn't want to put to much into it. I was hoping that maybe it was something that happens on all pfm42b2 sets and had an easy fix. Any help would be great. Thanks much Larry D
Thanks much!!! Still trying to get thru to sony. Phone number always seems to be busy. Sure wish i could speak with you in more detail about the repair. Thanks again Larry D
Posted on Apr 25, 2007
Call Sony at 1-877-650-3477 and tell them what happened. they SHOULD send a shipper to your doorstep free of charge to come pick it up and take it sony, where they should fix it free of charge, because this is a MFR defect that has happened to hundreds of this model. Trust me, I know I just did it yesterday :)
Posted on Apr 24, 2007
Flicker screen
If any buffer board is faulty, this kind of fault can occur. Might have a panel fault too. It will be best to contact any service technician, to make it confirm. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 16, 2013 | Sony FWD-50PX2 50 in. Plasma Television
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
May 16, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Rear projection tv colors flickering
Two types or more of sets: regular TV sets with a picture Tube, big rear projection sets, Plasma, LCD, DLP
A model number would allow me to give you the answer--I suspect you have a set with a picture tube(regular tv)
Let me know which so I can try to give correct answer.
Mar 28, 2012 | Televison & Video
My tv still has sound but the picture has went. It is displaying flickering vertical colour bands. Can this be fixed?
Yes the problem can be fixed.
The problem is from the t-com board of your television. Have it replaced and your television will be in good condition once again.
Take care
Sep 09, 2010 | LG 50PG6000 50 in. HD-Ready Plasma TV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Sony FWD-50PX1 plasma problem
Bad Plasma Display, time to buy a new one
Sep 02, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
122 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
