You can try clearing your cookies and history files first then manually disconnect your connection wait a few seconds and then tell it to reconnect give that a try
I am very skilled in wireless connectivity and networking. Chances are you have a driver issue. I am assuming you are trying to connect wirelessly. You need to right click your networking iconin the bottom right hand corner of the screen... Normally looks like a cell phone signal indicator.. See if you see your network in the list. From here what shows up will determine the next step ..
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer thanreplace the print head.
Normal
0
Normal
0
Driver could be corrupt. Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
