Question about Acer AL1711 17" LCD Monitor
Monitor goes black after a few seconds
I have an Acer 1711 monitor. The monitor comes on for only a few seconds and then goes black. What should I do?
  • 3 more comments
  • caturegli Dec 11, 2008
    Thank you for your suggestions. I tried unplugging the monitor and reconnecting it. The results were no different. Right now I am using a different monitor, so I assume the power supply and the memory aren't causing the problem. Could the monitor just have died?
  • davidgilmour Dec 15, 2008
    i have exactly the same problem, switch on monitor and Acer flashes on then desktop flashes and goes black. I have to switch on and off about 50/60times and eventualy the Acer comes on larger in size and screen holds and is then ok all day.
  • Anonymous Mar 22, 2009
    Had same problem. Fixed it like Solution #2 Had two dead capacitors thou, but the 1000 mf was one of them. Took the PBC to an pro. He changed them in 20 min time. Works like a charm
  • Anonymous Apr 22, 2009
    Yes i have same probleme bath i change cel 1000M 16v , 470m 16v and all ist ok !Tankcs!!!!!!!!!!
  • Anonymous May 01, 2009
    Solution #2 works. I replaced all 4 capacitors (2x470uF, 2x 1000uF) for sure.
I have the same problem on my Acer AL1711. The monitor was out of warranty so I opened it up and found one of the 1000 mf capacitor almost ready to pop. A 50 cents replacement from fixed the problem.
Not recommended for anyone without experience soldering electronic components to PCB's.
Posted on Dec 29, 2008
I changed capacitors 1000uf 16v and 470uf 16v.Monitor works as new...
Posted on Jul 01, 2009
  • 141 Answers
1) It could be your power supply is going bad or not strong enough to keep the monitor on.
2) It could be a memory issue. Video is one of the signs that your ram is bad.
3) It could be a loose connection or the monitor itself.
I would suggest first unplugging all the connections to the monitor and pc then plug in again and restart. If it still turns off try a monitor that you know works. If you still have the problem try changing your memory sticks. It's unusual that it would be a video card/ on board video because it usually either works or it doesn't.
Posted on Dec 11, 2008
  • Theresa  Smith
    Theresa Smith Dec 15, 2008
    Yes of coarse if changing the monitors solved your problem then I would say that you did great. Monitors do die. Power surges, moisture, age etc...
My monitor went dim and goes black after a few seconds. I can just turn off the monitor for a few seconds and then it comes back for a few more mintues but still is dim and goes black again. Also while...
I don't know what OS you have but there is a power management setting you might want to check. Most likely the monitor is set to go quickly into sleep mode at inactivity. Alternately I don't know what monitor you have but it might be a backlight Issue as well
Dec 20, 2017 | Acer X Computers & Internet
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
My priceton digital lcd 1711 comes on and will work for 5 or 10 minutes then the screen goes out and will not come back on until I turn the computer off and then back on
glasford22, You will need to do a bit of swapping to prove that your pc not at fault!! If 1711 does same when connected to different "known good" pc, then you may be dealing with "black screen of death" symptom. I'll bet you don't know the simple "flashlight test" that EVERY owner of a cold cathode fluorescent lamp, back-lit lcd monitor should know how to perform and interpret results of when confronted with a black screen. Have you been to YOUTUBE to view any video clips of owners /technicians that repair their units for less than $10? Just do some reading in my fixya profile and those of other tech's here on fixya ("budmrtn" "buddymc") .. You just might find solution to your BSOD problem. Good luck with repair. 12fixlouie
Oct 12, 2010 | Princeton Digital LCD1711 17" LCD Monitor
I have an Acer AL1711 monitor and its got a blankscreen
Sounds like bad caps in the power supply. C6 & c22 often need replacing. Check also R1, 10 ohns.
Monitor Mike
Apr 14, 2010 | Acer AL1715 17" LCD Monitor
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
Acer al2002w flickers and goes black
Well, you've got a busted backlight inverter... Need to replaced a new one...
Nov 30, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Acer 1711, entering sleepingmode in few seconds
same prob on mine gues its the inverter board but not tried yet
Jan 13, 2008 | Acer AL1711 17" LCD Monitor
Acer Al 1711 Monitor
Turn the monitor ON and continue to hold the power button for a few seconds.
Worked for me :)
Nov 09, 2007 | Acer AL1711 17" LCD Monitor
Acer 1711 LCD Monitor
My Acer AL1711 packed up last week, I bought a new Acer and noticed they have a 3 year warranty. Give Acer a call on 0870 853 1000, and they`ll do a warranty repair with free pick up and return - great service! Not sure if you need proof of purchase or not, luckily I had mine.
Apr 09, 2007 | Acer AL1711 17" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
1,119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
