Question about Garden
I have a craftsman lawnmower that will not stay running. When primed it runs great then dies shortly after.
  • John Jul 15, 2012
    Its a push mower, 6.5 HP. Model 917.388740 It ran great last week. Started always 1st and sometimes the 2nd time. It does start when primed but quits running shortly after. It did rain but not heavy two days ago and it was uncovered. But saw no water and it was 100+ degrees the last two days so water should not be an issue. I put gas in it and it started. Did two 20 yard strips and it quit. I prime it and it starts but quits right away. I read one post that replacing the plug could help. I will do that but I want any other answers while I try.
    The safety handle works because it starts when primed. Acting like no fuel because priming sends gas right to it and it starts but dies after a few seconds.
    Any suggestions? Possible water in tank but it starts when primed?
  • John Jul 16, 2012
    I did check everything and had to think a bit. When it would die, I'd press the prime once and it ran again. So it had to be the main fuel feed. I had changed the spark plug from another mower I have. Really no better. And the original plug looked fine. Only thing left was fuel. Fuel came out when I removed the hose to drain it into a bottle. I drained the gas and refilled it with new. Ran silly for a few minutes. But now running great. Had some rain and it was outside on the back patio ready to mow next day. It rained a little but it must have seeped into the gas. No new fuel and it was fine. Your solution is exactly what I did.
SOURCE: craftsman Lawnmower model #917.377292 won't stay running
pull the carb. and clean it and put a kit in it. This should give you a good start. Do a preventive maintenence of the rest of the engine also.Good luck.
Posted on Mar 26, 2009
rockitman187
  • 2559 Answers
SOURCE: Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
Posted on Apr 05, 2009
  • 79 Answers
SOURCE: lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Posted on Apr 06, 2009
steve_lima
  • 181 Answers
SOURCE: I have a Brigs&Straton 6.5 Quantum lawnmower will not stay running. I can keep it running by restricting the amount of air entering the carb with my finger (choking it) The mower will start if it
the problem is in your carb.,at the bottem of the carb. there is a bolt that threads in to the carb.pinch off the fuel line so that no fuel comes out after the fuel bowl is off the mower.now look into the bolt that you took off.there should be a hole oppisit the head of the bolt.there are also two holes that go through the sides.these holes are the fuel intake to the carb,the hole in the center is the fuel nozzle.most likely you have dirt blocking this hole and not letting the motor get enough fuel to run.thake some carb cleaner and spray it in the hole.take an air hose then blow the nozzle out.while you have the screw out take the bowl off and check to see if there is any water or dirt in the bowl.after cleaning.reinstall the bowl and start mower again.should be running ok now.if not let me know and i'll guide you through another fix.let me know if this helped or not................
Posted on Jun 02, 2009
  • 124 Answers
SOURCE: model no. 31as6fef729 544332 ser.no.11235B80204
This is a good time to remind everyone that you should not leave fuel in equipment that is not used on a very regular basis. More than likely your carburetor is gummed up from the old fuel. This can happen in less than 30 days much less 2 years.
To properly clean a carburetor you need to remove the carburetor and purchase the correct kit for the rebuild. Disassemble the
carburetor carefully making notes where each part goes. Once you have the carburetor disassembled clean it by soaking it in carburetor cleaner for a few hours. Use anned aerosol automotive carb spray cleaner to fill a small glass jar with enough cleaner to submerge the carburetor. Use a jar with a metal lid so you can gently agitate the solution occasionally to make the process more effective. You need to allow the carburetor to soak as long as it needs to remove all visible deposits. After the carburetor is cleaned allow it to dry and reassemble.
Posted on Sep 20, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman lawnmower wont stay running
Michael it sounds like there may be a blokage on you air filter. Check it and clean it then make sure there is not too much oil in the mower.
Jul 18, 2013 | Garden
Small engine repair
First check the air filter isn't blocked. If it isn't the carb is at fault.
May 29, 2013 | Briggs & Stratton Briggs Stratton...
I can start my 4.75 HP Briggs & Stratton Lawnmower but it dies after a few minutes. I replaced the armature but the same thing happens. I can keep it running if I press the prime bulb a couple of times...
Try replacing the float and needle. The float (floats) and pulls the needle up to let gas through to the carb. It will stay running as long as you press the prime bulb because this sends gas straight to the carb without going through the gas bowl. It's best to remove the carb and clean it then replace the float and needle
Sep 05, 2010 | Craftsman Garden
When I try to start my Craftsman Model # 917.388861 lawnmower, it will start and then dies right away, then Iit would start unless I prime it. Before it started doing this, the lawnmower was running very...
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 16, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
May 31, 2009 | Craftsman Garden
Craftsman DT4000 Running loudly
believe i had same problem this is what i did i took took the head cover under the carb and my needles was bent had to replace them now it works great again
May 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Craftsman Lawnmower model #917.377292 won't stay running
Mar 25, 2009 | Garden
Craftman lawnmower start and turn off and do not stay running .
your carb needs to be rebuilt. there is a rubber seat that swells over time and then your float will not allow any gas through. so it will start and run briefly when you prime it. take it to a mower shop for a tune-up.
Mar 11, 2009 | Craftsman Garden
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
