Question about GE Profile Wizard DPSE592EAWW Electric Dryer
Dryer drum causing squeak
I have a GE profile performance wizard electric dryer model dpse592eaww. The tub sits low in the front top area causing the dryer to squeak. Is this a belt, seal, or bearing?
  • Anonymous Mar 14, 2014
    GE 500A277P026 Electric Dryer squeaking
  • Anonymous Mar 31, 2014
    model DPVH880EJWW dryer
  • 126 Answers
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Posted on Jan 11, 2009
Dryer Squeaking/ Squealing
Could be a worn belt or, if it occasionally sounds like metal on metal, the felt that the drum spins against is probably worn through and needs to be replaced...
May 04, 2013 | GE Profile Wizard DPSE592EAWW Electric...
Have a G.E. DRYER PDVH515 . It squeeks, roughly on every rotation of drum. Not a consistant long noise.It's been going on for some time now so wondering if greater damaged may be done? Thankyou
The sound is most likely from the rear drum teflon bearing failing. It may also be the front teflon glides. Or both.
The problem is not going to get better and will gradually get worse. You won't do any real damage if you continue to use the dryer.
However, if the sound stops being a squeak, and sounds more like a grinding, metal to metal sound, stop using it and call the repairman.
Mar 10, 2013 | GE Profile Wizard DPSE592EAWW Electric...
When warm button hums but tub does not spin
With the door open, have someone hold thedoor switch in and spin the tub by hand while you press the start button and see if it will run. Post back the results.
Jan 20, 2013 | GE Profile Wizard DPSE592EAWW Electric...
The dryer is squeaking badly. how do i fix that?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 14, 2011 | GE Profile Wizard DPSE592EAWW Electric...
Dryer suddenly began making a noise. After doing an internet search, many sources said to replace the felt and slides. Which I did and some of the slides were in fact bad. However, after replacing them and...
It could be the rear bearing ( easy to replace). I would check the idler pulley and blower wheel assembly also. Here is a link that should help http://appliancehelponline.com/dryernoisyge.html
There are also several other videos that cover the idler pulley and front bearing assembly.
Jan 29, 2011 | GE Profile Wizard DPSE592EAWW Electric...
How do i oil the belts? The dryer squeaks every time its turned on?
You don't oil the belts on a dryer. This will cause the belt to slip on the motor shaft and/or drum. Oil permiated into the metal of the dryer drum can ruin it causing any replacement belt to slip as well.
If the dryer is squealing, you probably need to lubricate the idler pulley wheel at the axle point (also known as a tension pulley). If this is a GE model they usually have drum slides and a drum bearing that support the front of the dryer drum as well. When they wear down, they begin to make noise. The drum slides are made of teflon and not only help support the drum, but ensures it turns smoothy. You may need to replace both the drum slides and the drum bearing.
If the model number is correct, the part numbers are as follows:
Drum Bearing - WE3M26
Drum Slide - WE1M481 (Blue), WE1M333 (White)
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions, or if your model number is different from the one you listed this question under, please post back and let me know. I hope this helps you.
Feb 24, 2010 | GE Profile Wizard DPSE592EAWW Electric...
Squeaky DE dryer
there is a ball bearing in the back of tub in a plastic housing that wears out or the front glides on front of tub are wearing out,you can pop the top off and the front to check them out-mike
Jan 30, 2010 | GE Profile DPSB619ED Electric Dryer
Ge Adora Dryer, Worked great. Put load in, dryer 'hummed' drum did not spin. 'Clean Lint Trap' light was lit. Cleaned lint trap, still not working. Thought belt problem so unloaded dryer, drum did...
Sounds like your motor may be shot. Or possibly one of the pully's bearings are seized and is causing so much resistance the motor is unable to overcome it.
Oct 09, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
GE Profile Wizard DPSE592EAWW Electric Dryer Logo
366 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
