Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Fan on oven
The fan on my Jenn Air 47600 runs all the time now. It just started doing this.
  • 3 more comments
  • crohr56 Dec 11, 2008
    This is the complete model number on my range that the fan runs all the time SVE47600B
  • jedbuilders Dec 20, 2008
    the fan on my Jenn-Air SVE47600B will not shut off after it cools down . This is not fan inside the oven this is the cooktop fan that kicks on by itself while using the oven it usually shuts down within about 5-10 mins after shutting off the oven . it has been 5 hours now I even tryed turning off the breaker for a few mins
  • jewel62 Jan 03, 2009
    My fan runs continuously also after using my Jenn Air stove. The oven light also flashes on and off at first then continuously stays on the whole time the fan is running. They both stayed on for hours yesterday. (all day to be exact) Had to flip the breaker to get it to stop. help
  • godwithus Jan 03, 2009
    we are having the same problem also.
  • tvannoy May 24, 2009
    We have the same problem with the fan staying on; how did you get it fixed?
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
47600 this can not be the complete model number.
please look at the sticker in the range and copy the complete model number.
If this is a slide in range the # will be behind the kick plate below
Please remember to leave a rating before you leave
Posted on Dec 11, 2008
  • Neil Golan
    Neil Golan Dec 12, 2008
    There must be a bad fan switch or faulty fan. I would have to be there to test the parts. You may need service this time. It is not easy to get to taht fan!
  • Neil Golan
    Usually it is only a cooling fan and it goes off after your done and the temperature drops. Now I'm not there to make that determination. If the fan in a convection oven is running you can squat down with the oven light on and see it turning.
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
I need the Start Amprege for a Jenn Aire #WW30430P
phone jen air tech support daytime Eastern Standard time:
1-800-JENN-AIR (536-6247)
Dec 20, 2013 | Jenn-Air WW30430P Stainless Steel Electric...
The electronic controls click out with in just a few minutes after starting the oven. The light does not go on and nothing works. This problem started within one week of install and use and have had the...
Unfortunately this seems to be a problem with several of the jenn air models. I have replaced quite a few and have also talked to thier tech line for servicers and they don't have anything else to offer other than replacing the control board. Each time I ran across one I found no other problems and I tested everything. If you replace 3 times you can usually get them to give you a new one.
www.appliancehelponline.com
Mar 18, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air model# Sve 47600. No display.
Before you replace the clock try cutting the power to the stove for 10 minutes. This will reset the clock and it will sometimes start working again.
Nov 11, 2008 | Kitchen Ranges
JENN-AIR Oven shuts off and comes back on after several minutes
they are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Nov 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
220 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
