Question about Sony FWD-50PX1 50 in. HD-Ready Plasma Television
FWD-50PX1 wil not power up
Hello, I have a Sony FWD-50PX1 that will not power up. When I plug the power cord in I hear a fan turn on and it turns off a few seconds later. A few more seconds go by and it does it again. It cycles like this non-stop. Do you have any idea what would cause this and if the tv is worth saving.
Thanks
  • 7 more comments
  • ginahill742 Dec 11, 2008
    I checked partstore.com, they do not list a lamp for that model. Do you know of another place to find one?
    The green light comes on. I hear a relay switch. One second later I hear a fan turn on, it runs for 2 seconds an turns off for 5 seconds and the cycle starts again. The manual talks about a self diagnosis function of blinking lights for a code. I do not see a blinking light, only the green light on the front.
    Thanks, Jack
  • ginahill742 Dec 12, 2008
    "try to check out the circuit board's inside with a expert technician." So you think I should take this to a repair shop?
    The green light comes on. I hear a relay switch. One second later I hear a fan turn on, it runs for 2 seconds an turns off for 5 seconds and the cycle starts again. No picture no sound. Thanks, Jack
    Update: The 4 fans cycle 5 times and then stay on until the power switch is turned off. The the green light turns red. I check all the capacitors and I can not see any damage.
    The 4 fans cycle 5 times and then stay on until the power switch is turned off. The the green light turns red. I check all the capacitors and I can not see any damage. No picture or sound.
    still not working
    The original owner stated it worked fine and then stopped working one day. No sound also.
  • ginahill742 Feb 08, 2009
    I purchased a power supply from DISCOUNT MERCHANT. That did not fix the problem so I sold the tv as is for $160 and the guy I sold it to paid a repair shop $150 to replace capacitors on the power supply and the tv works great. And I lost $170 on the board I puchased from Discount Merchant. I knew the board was bad but I did not want to spend another $170 and take a chance on getting another bad board.
  • 10,594 Answers
If you have prior experience of TV repair and know high voltage risk involve in Plasma TV then you may check below mentioned voltage on given locations to check what supply is not working for further diagnosis.
Save above image to see enlarge view.
Posted on Dec 12, 2008
  • 275 Answers
Hmmm i dont think is worth spending money repairing it, Get it replaced by warranty or if you dont have warranty, there's other new tv that are cheaper than what it would cost you to repair yours
  • Alan R
    Alan R Dec 12, 2008
    pawn it and buy a new one
  • Sony Master
  • 4,806 Answers
Hi there
It has nothing to do with the "lamps" as its not a projector TV, it should on self diagnostics but isn't flashing, indicating that the TV has more serious problems like a power relay switch that has part blown (sometimes you cannot tell if are blown).
Sony say to cantact them with the flash code and they will tell you the problem, but in this case you don't have that luxury.
If the TV is still under warranty have it repaired by sony, if its out of warranty you have no choice but to consult a sony TV technician
kind regards
    Master:
  • 479 Answers
it can also happen if lot of dust accumlated on the internal main board of the tv.just open the back of the tv by removing the screws with a proper screw driver and clean that dust with a air blower on the board. then on the main board also check out for any loose transsistor or any burned component.if there is any replace that part.u can get this part at local electronic store or at radio shack websites.alsoinspect/suspect the power supply board (the one where the AC plugs in to) and measure the basic output voltages if you have a multimeter. Be careful not to touch or short anything else, including the high voltage used on the tube. this will clear the problem.
  • 2,334 Answers
Plasma Tvs do not use a lamp to illuminate the screen but different circuits and they are called Y sustainer, X sustainer boards together with left and right buffer boards; very often these boards (Y or X sustainer) become defective due to the amount of heat that is generated when they are operating.
If you are not familiar with electronics devices, it would be better to consult a TV repair to diagnose the failure and the tech will tell you what is wrong with your plasma.
Good Luck.
  • Jaime Hernandez Dec 12, 2008
    It seems like your plasma has 2 years warranty. If your TV is less then 2 years old, it might be still fixed under manufacturers warranty.
  • 734 Answers
Yes, its time to go a repair shop.
your Plasma Television needs repair.
Thanks
  • 505 Answers
Wow these people helping you don't know what they're talking about. A plasma has no lamp. Sony only made plasma TVs for 1 year and then got out of that technology. This TV is that hardest plasma I have ever worked on.. and I've repaired just about every brand. Any circuit board is going to run you $200 plus dollars. It sounds like a bad power supply as it does not go into a shutdown or spit out an error code. The power supply is about the only part that could be easily replaced, so there is a good chance of you repairing it, but it'd definately a tricky tv. Once you remove the back, there is a second back to remove (shielding).. If you get inside, you might find damage to the power supply. You can check the voltage outputs to see if there are any shorts on the Vs or Va lines, if so, the problem could be a drive board. Let me know if you want instruction to troubleshoot internally. This is definately a hardware failure.
  • Sony Master
  • 1,183 Answers
HI,
The best approach here would be to take it in for repairs , as working inside the TV cabinet would require prior experience with the electrical circuts inside,so that you donot risk any injury.
Thanks
proton
  • 76 Answers
Hi if you observe before the problem happen! if there is any color changes? if there is any color faded? its means less gas that why the protection control circuit cut the supply of the lamp
Posted on Dec 11, 2008
  • 75 Answers
Hello sir...
click this link between brackets and read the instructions and try it out thank you..
http://www.retrevo.com/search/v2/jsp/pdfViewer.jsp?doc=789a2d768cf8682538f72fa7344014a5&page=79&sectid=24&q=Sony+FWD-50PX1+is+not+switching+on
    Genius:
  • 2,920 Answers
Check the 4 capasiters in each corner of the tv if any of them look popped up you willl need to replace that one or possibly all 4
  • 365 Answers
The circuit board may have some compliant .i mean any one of the IC have been damaged which may sometimes cause this type of problem.try to check out the circuit board's inside with a expert technician.thank you
    Genius:
  • 1,550 Answers
You need to replace lamp on your tv .
It is easy repair only .
Order lamp from partstore.com
Hi I have a Sony fwd-50px1. It's plugged into the wall and without hitting the power on the TV the red standby light is on, as it should be. Now I press power on the TV itself and nothing happens. No...
Try unplugging and plugging the tv back in. Could also be a problem with the power button itself. Make sure the membrane contacts are clean and that the membrane is making contact with the contacts.
Dec 10, 2013 | Televison & Video
SONY KDE-42X5955 No Picture
Bring it to a tv repair guy. Youre not god.
Nov 23, 2013 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony pcg-grx52g/b not power ,when the power botton is press later it wil went off back and no more indicating charging.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 20, 2012 | Sony Computers & Internet
Where can I repair power supply circuit board for FWD-50PX1 monitor?
Any tv repair shops,look for them on the telephone Yellow pages.U mean litterly the power supply board taken out of the tv unit,yes,if they except the job.All tv shops,like their customers keep their parts in the tvs,Some charged u to come out and have estamate for the cost for repair some don't charge just look at the problems to telling u.
Feb 08, 2011 | Sony FWD-50PX2 50 in. Plasma Television
Hi, my tv just turned off on me. When I turn it on the TV screen flashes and turns off again. I have a solid green light on the power button but no sound or picture. Any ideas
HI:
There are bad capacitors on the power supply that needs changing. Also check the B+ capacitors on the inverter board also for leaky caps or caps that are puffy on their tops.
Jan 20, 2011 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Is there anywhere to purchase a HDMI card FWD-50PX1
I don't think they exist, I would try contacting Sony directly first.
Is it imperative you have HDMI? I can recommend an excellent HDMI to component video converter if you are using an HDMI only source.
Cheers,
Jan 06, 2010 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony KDF-50WE655 Was fine the picture went dim
Replace the lamp.Use an original Sony lamp. Next would be the lamp power supply and last, the optical block
Oct 13, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony FWD-50PX1 plasma problem
Bad Plasma Display, time to buy a new one
Sep 02, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Any assistance will be greatly appreiciated.
Sounds like you need a white balance adjust, call a local service center, you could do it yourself but you will need access to the factory mode, I don't know how to get into the factory mode for that model
Mar 14, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony FWD-50PX1 50 in. HD-Ready Plasma Television Logo
353 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
