Question about Dell Latitude D610 Notebook
Will not power up unless I move the display back and forth
This is an intermittent problem and when I get it to power on I can use it for as long as I like but if I shut it down sometimes it will start right back up but usually not PLEASE HELP !!!
  • cheryld3 Feb 22, 2009
    I have a Dell D610. When the computer is running...it works fine (runs a little hot, but it always has). As long as I leave the computer on...the computer will run for as long as I need it to. If it shuts down or if the power goes out and the battery doesn't last until the power comes back on...then the computer will not restart. When you press the power button...Nothing...No Lights...Nothing. I have tried pulling out memory chip/DVD drive, network card...everything. It doesn't matter. I have tried holding down the Fn key with the power keya and nothing. I have tried holding down the volume key with the power key...Nothing. I can pull the battery, unplug the computer from AC, let it set over night and the next day it will start normally (until it needs to be turned off again).
  • Isam Isam May 11, 2010
    Need more info to help with this. Could be a case of when shutting down the option to restart is selected.
    Problem Solver:
  • 17 Answers
Sorry I lost my password. This is a common problem with the 610 and other laptops. This repair is not for a Novice. Please get the maintance manual from dell go to dell support its free and know the disassembly procedures for tearing your laptop apart. Remove the bezel on top of your keyboard. The start button is on a small pc board. The problem is on the connector on the bottom of this board that commects to the Mother board of your computer. Remove all external, and plug in devices to your laptop. including the battery. After removing the keyboard, the top plastic cover, the start pc board, ect. you can see the connector from the start board that connects to the mother board. Look carefully and gently see if this connector is loose. The mother board connector is supported by 2 silver looking braces on each end. gently see if they are loose. I bet that one end has broken loose from the mother board. re solder the loose end to the mother board. be careful not to damage anything as I said this is not for the novice. (with the laptop in pieces put the startup pc board back in, temporairly put the battery in and push the start button. If the led's glow, this is where the problem is. While your laptop is apart check for dust ect. You may need to remove the heat sink , and a back support brace to get to the mother board connector to re solder it.
This has been a problem on 3 of my friends laptops Pushing on a button harder and harder doesn't solve the problem. It's not the button .Now you know the rest of the story.
http://support.dell.com/edocs/system/latd610/en/sm_en/index.htm
Hopes this helps just remember where all the extra screws go when you re assemble your laptop
Posted on Apr 02, 2009
What do you need help with? Hp Deskjet 2645 is showing error code and it refusrs to print
The carriage that goes back and forth when printing may not be moving freely. Turn off all power and see if you can move it back and forth easily. If not, put a drop of light oil on either side of the cartridge holder and slide it back and forth. You can also clean off the carriage rod with a cloth before oiling.
If this does not clear up the error code, the main board has failed and it will not be worth repairing, unless the unit is under warranty.
Oct 04, 2016 | HP Office Equipment & Supplies
How to fix a power seat that stopped moving
Unless you are mechanically inclined, take it to a mechanic who and either fix it, or install a new one.
Mar 25, 2015 | 2006 Nissan Altima 2.5
Oven Door Latch Won't Stop Cycling
Contact your power company and request they repair the appliance that was damage due to the surge, it is likely burned out the control panel
Jul 08, 2017 | Kitchen Ranges
HP Mini 1033CL intermittent or no sound
Probably something was touching the speaker cone and you snapped the speaker back so it no longer touches.
Oct 22, 2009 | HP Mini 1033CL Netbook
Intermittent dashboard light. light turns on after 20 minutes driving
Dirty dash-light brightness control? Try moving the control full-range back and forth a few times. Some WD-40 sprayed into the back side of the control might help.
Aug 08, 2009 | 1991 Toyota Camry
Rubbing sound in the steering column when making
It sounds as if your steering assembly is making contact with your main wiring harness.
Jul 06, 2009 | 2002 Chevrolet Tahoe
Sharp AR-157E unable to copy
Hello sir; Check the scaner unit, when you make copy does mirrow move out and return to home if not check the mirrow motor or cable.
May 28, 2009 | Sharp Office Equipment & Supplies
Canon MP780
i have taken the time to research this question on your behalf, the thing is the configuration on the canon needs resetting and also the data chip needs replacing, this process cost's alot more money than what the printer is actually worth, so my advise, buy a new one unless you have it under warranty, take it back
May 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer displays carriage jam
Leave the printer on without cartridges.
Unplug the power cable on the back.
Press & hold # 3 , While connecting power cord. When display says Partial reset ...Then follow the steps...
If this will not resolve, Carriage needs to be open & serviced / Repaired
Dec 14, 2007 | HP PSC 2410 All-In-One InkJet Printer
Dell Latitude D610 Notebook Logo
273 people viewed this question
Alun Cox
