Question about Acer Aspire 7110-2069 Notebook
No system found
My computer shut down completely it kept saying the system could not be found ,I reinstalled the recovery disks and it said it completed fine but then when i turn it on.. it still says no system found...does any one have any ideas?
    Problem Solver:
  • 11 Answers
Your hard drive is going bad, or its about to take a dump on you. Your best bet is to replace the h/d with one from best buy etc.
Posted on Feb 18, 2009
My computer harddrive files were corrupted and it said, "delete corrupt attributes (128""... or something like that so I reinstalled vista using the system recovery dvds. After it...
do you have the original system disk that came with your computer if so you need to try and reinstall your operating system. that will be the best way to get back to using your computer.
Mar 26, 2013 | Computers & Internet
Tip
How To Do A eRecovery Reinstall to ACER Factory Defaults.
.Heres 2 Very Useful methods
1-ACERs Original (x4) Recovery Disk/s
or
2-ACERs preloaded eRecovery ,
DISK RECOVERY CD (x4)
Put in System CD
F1 to Access BIOS
Set Boot order to CD in BIOS
EXIT and SAVE ,CONFIRM ,YES.
On Restart RECOVERY Mode will commence.
Follow Prompts when asked and in this order,
RCD1,RCD2,RCD3
Last Disk will be System CD to close the program and save your new settings.
This completed will give you a fresh install of ACER's Preload.
When restarts let the System install everything before you try to use it.
The system will shut down and restart a couple of times so no rushing will fix your problems with a Factory Default Install.
It should take 45min to reinstall
ACER eRecovery Preloaded onto your machine
Open eRcovery thru ACER Empowering Technology
Select RESTORE
Choose Factory Default,
This process is about the same time frame (45Min),
as the 4 disk method I have listed in the discription above.
These will not work if you have a password locked on the bios or the hard drive so dont lose your passwords,
remember to kept them safe always.
Hope this clears any miss understanding of how to use eRecovery.
Enjoy Cheers MISTERDJ
on Apr 06, 2010 | Computers & Internet
Error code f3-f200-0002 after recovery disks installed
Load the recovery discs again. This time when it gives you the options for Factory Reset etc., choose "Erase the Hard Drive."
Aug 23, 2012 | Computers & Internet
My Dell computer was going through startup repair so my Dad kept clicking ctrl,alt,delete and now it turns on but it says,
Says what??
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 24, 2012 | Dell Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
HELLO , I'M MY LAPTOP JUST AUTOMATICALLY SHUT DOWN , WEN I ON IT JUST APPEAR ON THE WINDOW IS INSERT BOOT DISK.WHAT CAN I DO TO THIS PROBLEM??? PLS HELP
Your HDD has crashed, it's asking you to insert your recovery discs in order to reformat the HDD with the complete operating system.
May 03, 2011 | Acer Aspire 5500 5570-2609 Laptop
My satellite a505 laptop has windows 7 on it and was wondering if i was supposed to get a disk with it so i could reinstall it
Uusally, now a days you do not get a disk with a new computer. Instead, if you go into the toshiba folder under programs on the start menu they will have a utility to make recovery disks. These disks can then be used to completely redo your computer should you need to.
Hope this helps.
Feb 21, 2010 | Toshiba Satellite A505-S6975 Notebook
My Compaq Presario 700 CM2130 failed to boot one day out of the blue. It just gave me an error message saying Operating System Not Found. I put in the disk for Windows XP and after a few minutes of loading...
When you get to the BIOS window, do you get a message saying that is going to shut down in some period of time of does it just shut down?
Here is my best guess and solution. I believe you've got a worm virus. If you have nothing that you want on this hard drive, and you've got a full install Windows XP disk, I'd do a full install with a complete format, not a quick format, FAT32, if you can, NTFS, if you can't and reinstall Windows XP.
Oct 18, 2009 | Computers & Internet
Tring to run restore disk but laptop kepts shut down
Maybe it's shutting down because it overheating. Check all your air vents for dust buildup. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. One time I worked on a Sony laptop that I had to take apart to get all the dust cleaned out of the air vent. You can also try running your restore disk with the laptop sitting right next to a window A/C unit. Try to position the laptop so it gets maximum exposure to the cold air of the A/C unit.
If you get the laptop working again and you think overheating is a problem I recommend downloading a free piece of software named FanSpeed. Here's a link.
http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature.
Jun 02, 2009 | Acer Aspire 5100 Notebook
A problem has been detected an window has shut down to prevent damage to my computer
boot into safe mode by pressing f8 at windows boot time,
run a check disk by rightclicking the harddisk, properties, tools, check disk
check both options for file recovery and system file fix, click ok rebboot
see what happens and get back to me
or
use a bootable media like the windows system disk to enter the recovery console and run checkdisk from there
get back to me
Dec 14, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 7110-2069 Notebook Logo
Brian Sullivan
Brian Sullivan
