Question about Dell 1700n Laser Printer
Dell 1700 often jams in one spot
Hi, every now and then, when I want to print, it always jams at the point where the paper is going into the printer. It doesn't actually jam, but its like it hasn't fully begun entering the printer if you catch my drift. It always happens the first time I want to print something, I just take the paper out again, and resume. It then begins to print. It doesn't seem like a major problem, but its very annoying. Can anyone tell me why it may be doing that?
  • 3 Answers
Just in case you don't know where the rollers are in the paper cassette...remove the paper cassette drawer and he rollers are at the top of the entrance to the drawer. There are two rollers, grasp one between your fingers and gentle pull the roller down to see the mechanism better. Rotate both rollers and you may find a build up of dirt/grime on either or both. Simple clean them with an appropriate wet cleaner & lint free cloth.
Posted on Mar 22, 2007
  • 4 Answers
Hi, Try to clean the rollers in the paper cassette.
Posted on Mar 04, 2007
SOURCE:
Paer prints half the PAGER AND THEN JAMS ... I
The paper must be hitting something to cause it to jam. Take the drum/toner cart out also the paper tray. Unplug it and hold it upside down and see if something shakes out. Do not do this over carpet. If that does not do try a test page. look at the leading edge for dings and bends. If you find a bent spot on the leading edge thats where the problem is. Its almost always a small piece of paper Steven 818-888-0006
Mar 08, 2010 | Dell 1710n Laser Printer
Dell 1700 printer will not print
Hi albrecht,
i think u might have used ur printer without paper often . unplug the printer from system and switch it off.Replug it again on the system ant switch it on and see. Even then if it is not printing uninstall the drivers for printers and reinstall again and print.
Mar 04, 2009 | Dell 1700 Laser Printer
Dell 1700
I've experienced this in the past and found a paper jam in the back feed roller and had to take the unit apart to retreave document. Try doing this (only if no longer under warranty) there are a few screws in the front and it should be able to come off easily.
Nov 10, 2008 | Dell 1710n Laser Printer
Jams
Check the sensor at the rear of the fuser. Sometimes sensor gets stuck.
Aug 12, 2008 | Dell 1710n Laser Printer
Paper jam dell 1720dn printer
I have taken the toner and the drum out to find a paper jam and could not find anything. I even turned the printer "off" and "on" and the "paper jam" light stays on. What can we do?
Celeste
Apr 09, 2008 | Dell 1710n Laser Printer
Dell Laser printer 1700
pickup rollers bad, you can try to clean them with rubber cleaner but it's best to have the rollers replaced.
Jan 22, 2008 | Laser 22 ppm Mono Printer
Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
103 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
