Question about Mitsubishi WS-55807 TV
My Mitsubishi hd1080 tv shuts off right after I turn it on. I tried holding the menu and the input buttons then it flashes in series of 2. Any suggestions?
    Top Expert:
  • Mitsubishi Master
  • 76,099 Answers
Flashes of standby lights are fault indications. Visit the site named "Electro-help' for details. Check this link, and select the site named above.
Posted on Jul 15, 2012
SOURCE:
  • 80 Answers
SOURCE: Mitsubishi CS-35301 35 in. rear projection. can't switch inputs
if you have s video connected some tvs wont allow you to use input 1 or 2.disconnect s video cable and try that other wise you got something wrong.
Posted on Apr 26, 2010
caroldon
  • 17130 Answers
SOURCE: Mitsubishi T.V WS-55815 How to go INPUT , NO
Please check with your remote , the input or video 1 will be found on the source or menu selector which can be scrolled with a view on the display.- on screen.
Check this out.
Posted on Oct 12, 2011
jerryg50
  • 1691 Answers
SOURCE: Power Problem
Most likely the power supply is failing, or some other circuit that is causing a safety shutdown.
Without doing the proper tests and diagnistics, it is impossible to accurately speculate the exact fault.
Jerry G.
Posted on Jun 01, 2008
  • 139 Answers
SOURCE: Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Posted on Dec 28, 2009
SD Tech
  • 14553 Answers
SOURCE: VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Posted on Mar 13, 2012
I have a mitsubishi HD1080 series TV and wanted to know how do I plug in a dvd player. Then how do I get it to play.
Connect an HDMI cable from the DVD's HDMI port to an unused HDMI port on the TV. Select the input from the settings menu and name it DVD or select the DVD name. Turn the DVD player ON. Using the input select button on the remote, select the HDMI DVD input. Wait a few seconds while the TV and DVD player establish a connection. The DVD player menu should appear. Insert a DVD and enjoy a movie. Hope this helps. Regards.
Jan 02, 2016 | Mitsubishi Televison & Video
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-A55, HD1080 Series TV picture scrolls horizontally
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Mar 05, 2017 | Televison & Video
WS 65313 Mitsubishi went black all of a sudden
hold down the menu and input buttons after it shuts off it will flash with a code. call tv repair place and they can tell you what code means.
Jun 04, 2009 | Mitsubishi WS-65313 65" Rear Projection...
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi Medallion Hd1080
Try to access the self diagnosis feature, by pushing the input/device and menu buttons in on the set itself and hold them both in together for 8 seconds to see if the led will blink a two digit code. If it doesnt that means the processor isnt powered so therefore its a standby voltage issue thos are usually easy to track down Try the proceedure to access the diagnosis feature then let me know the results.
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
TV Shutdown
Mitsubishi's have an error code system (press both menu and input/device buttons on the front panel, the green light will flash a 2-digit code...(example one flash short pause two flashes=12 long pause then it will repeat four more times...error 12 is no problem found...the other codes are 21,22,23 and 24.........Good Luck.
Sep 26, 2007 | Televison & Video
Mitsubishi WS-55807 TV Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
