Wiring -- I have a plug-in assembly for a hookup to a car radio and front and back speakers, which are labelled; not a problem, then there is a black power wire with fuse, I understand that, then there are also two blue wires coming out of the same hole, which also look like speaker wires but I don't really know.
and that is my problem, what are they and how are they hooked up and if, to what?
I'm told I need to use 8 ohm speakers, is that correct?
Hope you can help.
Thanks
Pete
This is for a Vintage Radio Reverb Stereo 68 made by Ranger Model # RR22R, sold by Allied Electronics in 1968. Normally, there is just wiring from the plug for front and back speakers, and sometimes they were hooked up to stereo instead of mono and maybe that is what those extra wires are for?This is for a Vintage Radio Reverb Stereo 68 made by Ranger Model # RR22R, sold by Allied Electronics in 1968. Normally, there is just wiring from the plug for front and back speakers, and sometimes they were hooked up to stereo instead of mono and maybe that is what those extra wires are for?
You can't post conmments that contain an email address.
Yellow - Constant 12V + Red - Accessory 12V + (switched) Black - Ground 12V neg. Blue - Power antenna turn on Grey(s) - Right front speaker (striped one is neg.) White(s) - Left front speaker (striped one is neg.) Purple(s) - Right rear speaker (same) Green(s) - Left rear speaker (same)
2006 Dodge Dakota Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Orange
This is the wiring codes 2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Brown/Red Car Radio Ground Wire: Black/Dark Green Car Radio Illumination Wire: Orange/Dark Blue Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: Dark Green/Red Car Stereo Amplifier Location: Located behind the glove box. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
the stock wiring is bare bones: 1997 Chevrolet Camaro Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange Car Radio Accessory Switched 12v+ Wire: Yellow Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: Pink Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6 1/2? Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Car Audio Rear Speakers Size: 6 1/2? Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Yellow Left Rear Speaker Negative Wire (-): Brown Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue
fun fun fun. 1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
2002 Toyota RAV4 Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Ignition Switched 12V+ Wire: Gray
Radio Illumination Dimmer Wire: Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
1996 Geo Tracker Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Negative Wire (-): Gray/Black
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange Car Radio Ignition Switched 12V+ Wire: Yellow Car Radio Ground Wire: Black Car Stereo Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 6 1/2′ Front Speakers Location: Doors Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Brown Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Dark Blue Right Rear Speaker Wire (-): Light Blue
provide a switched power source. Run a wire to the fusebox or ignition
switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
On new systems, like the one you bought to replace old one: grey and white are front, purple and green are rear. New wires should be labelled or shown on diagram on radio body. Stripes indicate negative side of speaker.
On your old loom: cut back behind plug, and strip wires at ends. Isolate power and grounds, and any that go hot EVER! Now checking just the remaining wires, use a AA or 9-volt battery, and touch pairs of wires to opposite poles of the battery. If you touch two that go to the same speaker, you will hear a slight static sound at that speaker: label these for that speaker, and so on. Once you get the pairs seperated and labelled by speaker location, the negs will be the striped ones, though you may not find they all have stripes. once you pair them, test in both polarity positions, the correct one will sound better right away. Should be able to reach max volume with little buzz or distortion. If not switch pow and neg sides. Hope this helps, TT
Here are the correct factory radio wire colors with definitions.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Black/Red Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6 1/2′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Purple Right Front Speaker Positive Wire (+): Green Right Front Speaker Negative Wire (-): Blue Car Audio Rear Speakers Size: 6 1/2′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Black Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Red Right Rear Speaker Negative Wire (-): White
