Question about HP Intel Pentium Dual Core Desktop Computer
Computer recently started stopping during startup on a page that I have to choose either f1 setup or f2 continue. it didn't do that before. I want to bypass that page
  • Anonymous Mar 21, 2014
    i have a problem when i start my pc i see f1 to continue at startup how i will remove this add during startup
    Scholar:
  • 86 Answers
This is a bios issue... Most likely you need to press F1 and then Save and Exit and will go away... Sounds like a checksum error or something is off in the BIOS and it is letting you know ; )
Posted on Dec 11, 2008
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Hi, i want to set up cd drive on first boot. How do i can access to setup?
If I don't know what computer you have It makes helping you more difficult.
Here are some options for different computers:
  • Turn on the computer, immediately hit the F2 button. - Most computers with Phoenix BIOS.
  • Turn on the computer, during POST hit the Delete button - Most computers with AMI BIOS
  • Turn on the computer, hit Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1 - Older Lenovo.
  • Turn on the computer, immediately hit the F10 button. - Some Dell computers.
  • Turn on the computer, hit Fn+Esc or Fn+F1. Older Dell laptops.
If you tell me exactly what you have, I'll tell you exactly what to do ;)
Jan 28, 2011 | Computers & Internet
My dell d2400 will not boot up, I get the primary drive 1 not found, strike f1 to continue, f2 to run the setup utility
when the operating systems was setup on your hard drive, the incorrect partition was set. this causes that screen to appear. more often people will choose that way so that you may have full advantage od a smaller hard drive. this will not affect the performance of the system in any way. the fact that you have to hit the f1 key on startup is just an inconvenience.
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
Turn on my computer Inspiron 530S starts to boot up gives the dell booting page then goes to 0 Diskette error choose F1 to continue and F2 to start setup. I have tried F2 and change it to no floppy disk...
Sounds like someone may have left a non-bootable floppy disk in the drive. Check to be sure there isn't a floppy in the drive. Also, when in setup, it's the boot order that you'll want to change.
Nov 27, 2010 | Dell Inspiron 530s Desktop Computer
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Problem when i start my computer have a choice F1 and F2
just insert the xp cd and choose repair in it .......it will remove the error message
Jun 20, 2008 | 10 10 Computer Network adapter Cable...
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
HP Intel Pentium Dual Core Desktop Computer Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
