Question about Dell Inkjet 720 Printer
Spooler Service When I tried to use my printer my computer could not find it. So I uninstalled and attempted to reinstall it, but the installation process gives me a messages saying it is unable to install the printer b/c my spooler service has been stopped and that I need to start it. What is a spooler service, why would it have been stopped, and how do I restart it? Thanks!
Restart the spooler service by going to Start->Run and type "services.msc" without the quotes and restart the serverice Printer Spooling by right-clicking it and pressing start. A reboot will also fix the problem.
Posted on May 04, 2007
I got an installed printer, and it can't print. It seems that my PC cannot read the printer, like there is no printer installed. When I try to uninstall the printer and to install again the error
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Jan 11, 2013 | Office Equipment & Supplies
Hi...i have a Brother MFC290-c all in one setup. My printer was working fine and then one day it stopped. I have tried to reinstall but says Printer spooler failure whatever that means. I went to look at...
Hi. Printer spooler is not running on your computer or there's a need to erstart the printer spooler services. Please refer to steps below.
1. Press Window key + R to open the Run dialog Start and type services.msc and click OK.
2. Double-click the Printer Spooler service, and then change the startup type to Automatic. This sets the Spooler service to start automatically when you restart the computer. Click OK.
3. Restart the computer and try to install the printer again.
If that doesn’t work, the problem could be related to corrupted printer drivers that are installed on the computer. Try uninstalling all printer software from the computer and start from scratch. This may include PDF writer or faxing software as well. Anything listed in the Control Panel under Printers & Faxes I would do away with. If there is any software installed for other printers in Add/Remove Programs I would uninstall it all. Clean out everything possible that might be hanging the Printer Spooler service. Obtain updated software from your printer manufacturers and reinstall only the items you need.
Have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 10, 2010 | Office Equipment & Supplies
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Print Sooler not installed
HI
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Nov 08, 2008 | Dell Inkjet 720 Printer
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
73 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
