Question about Philips HDD1630 MP3 Player
Cleaning is a disaster + a bucket of water
I was cleaning the floors and my mp3 ,a philips hdd1630/17 somehow managed to fall into a bucket of water i took it out and the first few minutes after it was fine.i got a blow dryer and dried it and i turned it off b/c the battery was low then i try to turn it on and it gives me a blank screen am i doomed?I am willing to get it repaired but i don't know of any places in philly that repair them ,they only do ipods.should i give up or do it myself .is there a way to unscrew the back though so i can dry off the inside completely?
  • 8,596 Answers
Sorry - it is a goner.
Posted on Feb 11, 2008
Trouble with disposing of water. I have it hitched up with hose, but humidifier insists on filling the interior bucket. Help please
For the hose to work the unit must be elevated somehow so that the bucket will not fill. Or somehow the unit must be higher than the end of the hose. If you put the hose down an open floor drain that should suffice.
Jul 12, 2015 | Soleus Dehumidifiers
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
Dehumidifier water is not collecting in the bucket but is falling out and is dumping on the floor
Check the collection bucket, to make sure it is installed tightly. If that checks out OK, the drain hole or tube that dumps water in to the bucket is clogged. To clear the clog, remove the bucket and look up under the top were the bucket rests. There will be a hose or a drain tube, Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers), that will fit into the hole or tube, carefully insert The Zip Tie and push it into the hole or tube. The Zip Tie will reach a bend in the tube that you need to gingerly, work it past the bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out, while rotating it. This will dislodge the clog. Once you have the Zip Tie almost removed, be prepared for some water to follow.
The above should solve your problem. Hope this info helped you.
May 27, 2011 | Goldstar DH304 Dehumidifier
Quick upright defrosting
Good day,
The aerosols help. But, hurry up with any type of refrigeration equipment is many times a quick way to disaster.
Go slow and thorough. A little lost food is far better than a messed up machine.
Patience is your friend here.
Apr 30, 2010 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Occasionally the ice cube maker overfills causing the water to fall to the frezzer floor and leaking onto the ground, any suggestions on how to fix this?
Are you sure its the icemaker overflowing? if it is, you will have icycles on all the shelves and the food leading down to the floor of freezer. If you have NO icycles between bucket and floor, you have a clogged defrost drain problem.
If you do have icycles between bucket and floor, you will also have a big block of ice in your ice bucket. without personal inspection, i would advise replacing both the ice maker and the water valve(s)
Mar 18, 2010 | Frigidaire FRS26H5AS Side by Side...
SA9200 device manager problems
OK - you messed up somehow. Instead of downloading the Philips Device Manager from Philips' official site, you have downloaded malware. The only legitimate source for the Philips Device Manager is www.usasupport.philips.com
Download the legitimate version and plug your mp3 player into the computer. The "Repair" button will then appear.
-Tha Mp3 Doctor
Feb 19, 2009 | Philips SA920017 MP3 Player
Sa6045/37 and a new computer = disaster
www.usasupport.philips.com - enter model number, click on the version ending in /37, and click on "software and drivers"
Jun 08, 2008 | Philips MP3 Player
Computer recognizes the player as a CAMERA
Go to www.p4c.philips.com
There is a download that fixes this problem
Aug 18, 2007 | Philips HDD082 MP3 Player
Computer reads the player as a CAMERA
i know mine does that to but i tried it on may computers and having windows meadia play 11 always works
Philips HDD1630 MP3 Player Logo
32 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
