Question about Cobra 29 LTD CB Radio
Not the right sound
Sound is put put put put put put put I need a print
  • 3 Answers
If the sound is popping on receive you more than likley have a bad audio ic (TA7222AP)
Posted on Dec 12, 2008
This may sound wierd, but I accidentally printed a whole book on the computer when I only needed a small part of it. I turned the power on and off, and it would restart from the 1st page then continue...
Find your printer (in the start menu//control panel//printers and faxes). Open your printer and find the print que. Highlight the document and right click pop down. Locate and select cancel.
Should do it.
--W/D--
Jan 14, 2011 | Office Equipment & Supplies
Z4M printer when printing on a 3.75 wide label the left side prints fine and the right side is missing half the print. Also continuous wrinkles in the ribbon causing gaps in the print. I tried different...
There is a tensioner that holds the printhead assembly down, slide it more to the right. It sounds like you just need a bit more pressure on the right hand side of the printhead.
Sep 28, 2010 | Zebra Z4M Printer
How do i release the Kodak 5100 print head to change it
here is the link to check how to remove the print head with pictorial discription www.kodak.com/go/printheadsupport you can also visit www.kodak.com/go/inkjetvideos . You need to take both the ink cartridges out first and right where you put the black ink cartridge all the way to the back of it in the plastic tray pinch in the top right hand corner and push upwards you will hear a click sound and it will be released..........to put it back in you just need to push right in the center towards back and should snap in.............m sure this would be helpful...
Jul 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Not printing microsoft office documents, VIsta Software
Try to press the photo and copy at the same time it will print a diagnostic page
look how is the quality of the text.
if it prints very light or if it doesnt print open the access door and try to remove the ink cartridges and put it back again and make sure you hear a click sound after you put the cartridges back in and close the printer access door
try to print again a demo page press photo and copy and check if there is improvement
if no improvement open the kodak aio home center software click on the question mark(?) on the upper right corner and click on maintenance..then select printhead cleaning.After the printhead cleaning print again demo page (press photo and copy at the same time) if still no improvement on the quality of the text call the kodak hotline 1 800 421 6699..you might need a printhead replacement..
Nov 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing color copies
check to see which cartridge you put in, photo magenta cartridges DO NOT work in the MP830. sounds silly but we see it all the time.
check to see if the short vertical black bar next to the magenta pattern looks ok, not brown or gray or streaky. if it is you may need a professional head flush, take the whole printer in for service.
Jun 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma iP1000 does not give clear print
It sounds as if you need a new printhead. Try contacting Canon, who can put you in the right direction
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printing Alignment
hello!
It may be one of the cartridges is defective. Try replacing the cartridges to see if the problem clears or the printer just need a little clean up. you may also try this
Step 1: turn printer off.
Step 2: unplug power brick.
Step 3: MANUALLY move cartridge carriers towards the center.
Step 4: take cartridges out.
Step 5: move carriers to the RIGHT.
Step 6: CLEAN the shiny silver bar that is connected to the carriers using a dry cloth, from left to right in one direction.
Step 7: move carriers to the LEFT.
Step 8: CLEAN the shiny silver bar that is connected to the carriers using a dry cloth, from left to right in one direction.
Step 9: move carriers to the RIGHT.
Step 10: CLEAN the see-thru tape that is connected to the carriers using a dry cloth, from left to right in one direction. (careful, it is delicate, clean both sides).
Step 11: move carriers to the LEFT.
Step 12: CLEAN the see-thru tape that is connected to the carriers using a dry cloth, from left to right in one direction. (careful, it is delicate, clean both sides).
Step 13: put power brick back in. turn printer on.
Step 14: put inks in.
Step 15: press check to print alignment page.
If the problem persists, possible that the printer is defective
May 09, 2008 | Dell 926 All-In-One InkJet Printer
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
Printer prints backwards/upsidedown
This sounds like an advanced setting on your printer setup. When you get to the print dialog, hit Properties for your printer, then look around there for a "mirror" or "reverse" setting. Different printers use different drivers, so your configuration options are difficult to predict.
Apr 18, 2007 | Brother MFC-5840CN All-In-One InkJet...
Cobra 29 LTD CB Radio Logo
116 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
