Question about Goodman GMS90703BXA Heater
Furnace runs on utility power but not on back up generator power
Currently my goodman furnace will run on utility power which is 124volts measured with a digital meter. When my power goes out and switches over to generator power (power is automatically transfered) furnace will not start up. Voltage at the unit is 128volts. Does this furnace have a high or low voltage cut out. From the wiring diagrams I don't see one but am at a loss for why this unit isn't starting back up. Thanks for you help
  • jason May 11, 2010
    that is high for voltage output from utillity , mine is only 119v ac at the most,
    also does these voltages go into a module( seperat inputs ) ?
    the generator voltage may be to high if not regulated and or if current is to low( which cannot be checked with a regular digital volt ohm meter ) because they only go to ten amps. so if its higher
    how are the lines hooked up? and to what?
    also what do you mean it won't start back up? with the utility power either? also what is the model , make # ?
I had the same problem with a GH8 Goodman. In the instructions for the furnace are the sentences, "1.Measure resistance between the neutral (white) connection and one of the burners. 2. Resistance should measure 10 ohms or less." Mine was .2 ohms with grid power. It was in the Meg/ohms when on the generator. I made a special extension cord to open the ground at the female end of the cord. Then I connected the neutral (white) wire in side the furnace directly to the ground connection inside the furnace and it worked. Needless to say I was very happy. I do not recommend doing this yourself. This is just my way to stay warm this winter when the power goes out. JohnS
Posted on Dec 23, 2008
Using the Hz meter you can adjust the governor throttle screw to raise or lower the engine speed
to get an optimum 60-62 Hz setting. You may want to load your generator with the most
common load you will be using and then adjust the screw to give you an adjustment within the
60-62 Hz range. If you set it too high, then it means you are running the engine faster than
need be and will add to premature or serious engine damage to the internal parts. It is
mechanically governed to maintain the proper engine speed once it has the standard setting in
place. Do not attempt to adjust this governor throttle adjustment screw without the proper tools
available. You can not do it by ear! If you do not have a Hz meter or tachometer available, then
you can use a conventional electric clock with a sweep hand for seconds. If you plug the clock
into the generator, a proper engine speed would make the clock do a minute in exactly 60
seconds against any other timing device. If the clock takes longer to do a timed minute, then the
engine speed is too slow and you need to raise the engine speed; turn the governor throttle
screw clockwise. On the other hand, if your clock does a minute in less than a normal clock
minute, then you need to lower the engine speed, turn the governor throttle screw counter
clockwise. Now you should have a good setting for your generators frequency setting. It is best
to do a frequency setting before doing any voltage adjustment.
I did this today and my Goodman fired right up after two days of frustration!
Posted on Dec 07, 2009
Why does inducer motor run nonstop on goodman furnace?
possibly a board issue does inducer shut off when no call for heat
Jun 12, 2015 | Goodman Heating & Cooling
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Goodman furnace wont come on
If this is a High Eff furnace:
1) Remove the compartment that has the igniter and burners, turn the
power back on, if the furnace lites then you have a problem with the
intake air vent, probably iced over if you live where its cold.
2)Make sure the exhaust vent is not getting backpressure from the
wind.
3) you could cut the pipes on the inside of the house to disconnect them from the furnace, test run the furnace with no pipes.If the furnace
runs then you have a problem with the installation of the vent pipes.
4) Do not run the furnace without the exhaust pipe disconnected,
go to the hardware store and get a couple of rubber clamped
couplings and hook-up the exhaust pipe!
Good Luck
Jan 09, 2010 | Goodman GMS90703BXA Heater
I have outside Goodman-Janitrol furnace and air unit and
two things to try first to get you pointed in the right direction. First disconnect the R or RH wire from the T-Stat. If the furnace turns off (Stops firing w/ fan to turn offabout 90 sec. later) then you more than likely have a bad Thermistat. If it continues to run Pull the R wire from the Furnace circuit board. put door back on furnace if it stops you have a short in the wire. Still Running? Most likely a bad curcuit board. Hope this helps.
Oct 12, 2009 | Goodman GMS90703BXA Heater
Generator will not run furnance
What is the voltage level from the generator? Does the furnace run fine on electric? What is the Btu or Wattage rating of the furnace? What is the Wattage rating of the Generator?
Oct 04, 2009 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
1,607 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
