Question about HP 49g+ Calculator
Unable to connect calculator to computer.
Attempitng to connect calculator to computer. Computer will not see calculator. Using software from HP that came with calculator . Computer software is Windows XP. When attempting to connect; an error comes up; (no device detected. Check the cable connection and the calculator). Replaced cable with new cable. Went through trouble shooting process from the software. Using keys: (App),(i/o functions),(transfer),change type to (xmodem). Tried (xsen),tried (xserv),tried (start server).No results.
  • Wayne Terry Apr 10, 2007
    In addition to the help from the guest, I found that the USB drivers were not properly installed. Working with HP I followed the instruction below to connect to the computer:
    To see if your USB calculator driver is installed on your Windows
    Computer:
    1) Click the "START" button
    2) Go to "Settings"
    3) Select "Control Panel"
    4) Open the "System" control panel
    5) Select the "Hardware" tab
    6) Click the "Device Manager" button
    7) Expand the "Universal Serial Bus Controllers" group by clicking the
    [+] next to the group name.
    8) Turn your calculator on and connect it to your computer using the USB
    cable.
    9) If the computer already has the USB calculator driver properly
    installed, "HPx9G+ DEVICE" should appear under the USB group with a USB
    icon next to it.
    10) If the computer does NOT have the USB calculator driver properly
    installed, a device should appear under the USB group with a yellow "!"
    or "?" over the icon.
    If your computer does NOT have the USB calculator driver properly
    installed:
    1) Right-click the calculator device with the "!" or "?" icon and select
    "Properties"
    2) Select the "Driver" tab
    3) Click "Update Driver"
    4) Progress through the driver update menus until they ask if you want
    to locate the driver yourself. Choose this option.
    5) When the menus ask to to select the driver location, navigate to the:
    C:\Program Files\Hewlett-Packard\Conn4x\USBDriver
    folder. This is the default location for the USB driver if you have
    installed the calculator connectivity software; if you have installed
    the software elsewhere, you will need to na
    6) Select the above folder, and continue through the driver installation
    menus.
    7) If the driver installs correctly, the calculator should show up as
    "HPx9G+ DEVICE" with a normal USB icon under the USB group in your
    Device Manager.
    Problem Solver:
  • 19 Answers
I have a HP48G. I connect thru HyperTerm. I bought the SIO cable for the Caclulator, and you have to set the I/O on the calculator. For files transfer I use Kermit. Still using HyperTerm on the Computer.
Works for me.
You have a HP49G, I don't know if it is SIO or USB, I don't see USB support on HyperTerm.
Good Luck
How's the programming going on that? I call it Object Programming.
Posted on Jan 08, 2008
Try opening the software on your PC. Set the connection to USB and connect your calc. On the calc press the right shift key followed by the right arrow key.....software should now recognize the calc.
Posted on Mar 24, 2007
SOURCE:
Unable to connect with desktop through usb cable
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
I'm unable to send to, or receive from, my PC files.
Kermit is a protocol designed to allow two computers to communicate with each other.
The HP 50g is not compatible with Microsoft Word. You can write programs on the 50g, transfer them to the computer, and transfer them back, but you cannot edit them in Word.
There are other PC program that will let you write and edit 50g programs. There are also many communication programs. Take a look here.
You may want to consider getting an SD card (and if necessary, a card reader for your computer). It's a lot easier and faster to transfer data and programs using the SD card than the wired connection.
Jun 27, 2012 | HP 50g Graphic Calculator
What is the process to save a document or picture scanned with my HP Deskjet F4280? I am using Microsoft Windows 7. I am unable to install any HP software for this printer/scanner while using Windows 7.
There is no need to install any software for scanning from Windows 7 computer.
It's very easy
On computer click "Start" (windows icon)
click "All Programs"
click "Windows Fax and Scan"
click "Scan" and complete the scan as per on-screen instructions there
Make sure printer is turned on and connected to computer through usb cable properly.
Dec 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
How do I send my graph from my 84 plus silver edition to my computer?
  1. Install the TI Connect software on the computer.
  2. Connect the calculator to the computer using the Silver Link cable or the USB direct cable.
  3. Run the TI Connect software and let it recognize the Calculator.
  4. Once this is done, create the graph on the calculator, and click the screen capture button in TI Connect.
  5. Save image in jpeg format.
  6. Send it to the printer to print or insert it in a text document which you then print.
Dec 15, 2010 | Texas Instruments TI-84 Plus Silver...
I am unable to connect the device of the printer hp 6310 using the USB cable during the installation . any solution ???
Make sure the printer is plugged into a live power outlet and is turned on.
Disconnect the printer from computer.
Remove all software you installed from the printer from the computer.
Restart the computer.
Install the printer software.
Do not connect the printer until you are prompted by the software.
If nothing is broken this will take care of your problem.
Apr 17, 2010 | Office Equipment & Supplies
How can I print graphs?
  1. Create your graph on calculator.
  2. Connect the calculator to the computer using one of the two methods: SilverLink Cable of the USB Direct Cable.
  3. On the computer RUN the TIConnect Software.
  4. In main window, find the TIScreenCapture icon (it is afflicted with a Camera and a curve graphed)
  5. Click the TIScreenCapture and
  6. save the image in jpeg or png format (bmp format file are too big)
  7. You will be able to print it from the computer using an image editing software,
  8. or insert it into a word document and then print the document.
Apr 17, 2010 | Texas Instruments TI-84 Plus Calculator
It says that i have to download new software, but dnt know how.
Use the following link to go to education.ti.com
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2
to download specific software for the TI83PLUS (Operating system , Apps or others.)
Use this second link to download the TIConnect software for Windows (if you use Windows). You may already have the latest version on the CD that was with the calculator.
http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=1&appId=183
Install the TIconnect software on you computer. Execute TIconnect. Then connect you calculator to the computer with the TISilverLink Cable. Turn calculator on.
Verify that connection is established by clicking the TI Device Explorer icon in the TI connect main window. If it is established, you can Cilck the Update button at the top of the TIconnect Main window. It will update The OS, and the applications that are installed on you calculator.
Later if you go to education.ti.com and find other applications you would like on your calculator, download them on your computer. If you run TIConnect software you will be able to drag an application and drop it on the TIConnect main window and it will be installed on your calculator.
Hope it helps.
Sep 16, 2009 | Texas Instruments TI-83 Plus Calculator
Unable to connect to computer
Try using a separate card reader to download your pictures.
Sep 05, 2009 | HP Photosmart M547 Digital Camera
My calculator does not connect
I hope your using the silver link cable between your calculator and computer. My computers seems to only work with the black serial link and ti connect. I found a few computers actually download and work with the ti89 or ti 84 graphic link software. Ti Connect Device Explorer works for me but, the graphic link software may work for others.
Dec 13, 2008 | Texas Instruments TI-89 Calculator
HP 49g+ Calculator Does Not Turn On
Try n cold start, reseting the calculator, introducing an wire in the back small oriffice in the calculator. It may fix the problem.
JC
Mar 26, 2007 | HP 49g+ Calculator
HP 49g+ Calculator Logo
1,972 people viewed this question
Clive
Clive
Thomas F. Schneider
