Question about Philips 32PT8302 32" TV
TV WILL NOT COME ON
My philips 32" tv clicks when press the power button then if you continue to press the power button a picture will come on when the tv will turn its self off again you keep repeating the process and it will stay on for about 20 minutes then go off again. What could be the problem?? its very annoying!
    Novelist:
    Champion:
  • 236 Answers
You might have a relay with bad contacts OR a loose or burned loose resistor in the power supply circuit. Stargazer
Posted on Mar 10, 2007
SOURCE:
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i change screen format so picture will fit tv screen
Look on ur tv remote control for a button that said like Viewmode,Aspect Ratio,Picture Size or Zomming.Used one of these buttons keep pressing until the format of the picture that fit on the tv screen panel that u like?
Aug 06, 2011 | Philips 32PFL3505D 32 in LCD TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
How do i program my jumbo un remote for my tv,vcr/dvd player with out getting charged for it?
hold down setup button 2 sec press tv button once press power until tv turns off then press enter or tv if u dont have enter button
Aug 27, 2009 | Philips Magnavox TS3260C 32" TV
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
Philips 32'' when turned on picture goes off after 5 seconds
hello. ok try this. first take the remote's out of the room the tv is in.!!! yes both of them. then i want you to turn the tv on with the power button on the front of the set. and tell me what .? happen's..and please dont try to turn thechannel or any thing else !!! .just turn it on.!!! "am" waiting
Jan 03, 2009 | Philips 32PT6441/37 32" TV
Total Factory default of Philips 37pfl9703
hold down menu button on set until it does a factory reset
Dec 07, 2008 | Philips 32PF9966 32 in. HD-Ready LCD...
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Trouble Turning On
is this a lcd projection or just tube projection
Nov 15, 2007 | Sony KP-46WT500 46" Rear Projection...
Philips 32PT8302 32" TV Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
