Question about Tappan TEF242 Electric Kitchen Range
Tappan mef500pbwd range thermostats go odd about every 2 years
I keep putting in part #5303285955 every 2 years because the oven temp no longer holds steady.
The three thermostats have been of Mexican manufacture.
Any ideas?
kb
catriver
  • 878 Answers
SOURCE: Tappan Range Model TGF657BFWS
Delo, I am not finding that model number, what I have that is close is the model number tgf657bfw5, if this is your model number the F1 code is a bad electronic control, part number 318010300. If this is not your model number, just ignore this post...Catriver..post back
Posted on Aug 07, 2006
Rotu
  • 175 Answers
SOURCE: oven not always working
MOre than likely your igniter is getting weak. If it doesnt pull enough amperage. it shouldnt let gas into the oven. If it is letting in gas and not igniting, I would suggest a new igniter and a new safety valve. Hope this helps!
Posted on Nov 23, 2006
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
  • 131 Answers
SOURCE: Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Posted on Mar 10, 2008
huuum
  • 750 Answers
SOURCE: Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Posted on Sep 24, 2008
I have a used Tappan gas range with 4 burners and a griddle in between the burners. everything works, but the oven temp varies about 40 degrees above and below the setpoint. it never seems to level out...
not normal
problem thermostat not lighting the gas or turning the gas off to maintain an even temp
temp variation should be around a 10 degree range
call a gas fitter to check out the oven controls , thermostat or thermocouple
Sep 19, 2017 | Tappan Kitchen Ranges
Turn on the oven to preheat and it stays cold
There are usually only 2 things to check on a tappan. The thermostat or the igniter. The Temp control is pretty sturdy on these, so the order of failure will be, igniter first, then thermostat.
Mar 23, 2010 | Tappan TGFS_63 Gas Kitchen Range
My gas oven had a wide range in holding the temp.
Hi no the thermostat is what is called a liquid type cannot be done new thermostat is the way to go
Dec 27, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Oven temp off
You either have a plug up in your flame from dirt etc.
or your valve needs to be replaced.
Try turning off the gas and getting to the burner and clean it first.
Mar 22, 2008 | Tappan TGF320 Gas Kitchen Range
Feb 08, 2008 | Tappan TGF320 Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan gas kitchen oven will not heat
Almost always a weak oven igniter. Remove oven floor by removing 2 screws at rear of floor. Remove flame spreader from burner, if it has one. Turn on oven and see if igniter gets red. It's the caged thing on burner tube. If it does but doesn't light gas, replace igniter. UNPLUG UNIT FIRST!!
Put dishwashing soap on threads of 2 screws holding igniter in place. This will allow it to come out easier. Do-not use oil. It will make your oven smell like a diesel truck.
Remove screws. You will have to remove drawer in front. Underneath you can fin wires from igniter. These will be cut at igniter and connected to igniter with enclosed wire nuts. The 2 wires to igniter go either way.
Nov 22, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TEF242 Electric Kitchen Range Logo
113 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
