Question about Sony STR-DA5ES 6.1 Channels Receiver
Sony receiver DA5ES. Unit start arc and shoot off.
Several months ago my DA5ES start making arching sound 3-5 minutes after turned on, than continued to play  with no problems. Recently there is not arching but after 3-5 minutes unit display's flashing "please power off". So fare unit works only on stereo setting. We were using only 3 speakers and powered sub. Movies were watched on sony cinema sound setting, Cd played on ADF decoding and radio on sony cinema sound, opera or ADF decoding. Unit is 7 years old and it was listen on 1/4 volume cca  -65 db
Is unit defective and is it worth fixing it.
Thank you for looking in this matter
Sincerely,
Marko Gosar
Have the same issue with mine, deciding if it's worth it to fix. I tried canned air to blown out internals, worked for about a week then same poping noise and message. I think it's something to do with the detection for 6.1 and then tries to overdrive speakers and pop!
Posted on Aug 06, 2010
Marko,
I own the same unit (since 2001) & have had no problems. I would get it looked at & see what the issue is & what it would cost to fix. Would it be worthwhile? Well you'd have to ask yourself how much $$ you'd be willing to spend on a replacement vs repairing this unit & based on how much you'd be willing to spend, would the specs on a replacement unit measure up. You'd have to ignore things like HDMI inputs to keep it apples to apples.
I've owned various Sony components for a long time. I only had to get one unit fixed one time (a CD player that my one year old decided to do a chin-up on :( ). The unit was 7 years old at the time and my son is now 12!!. the unit still functions flawlessly since being repaired. Sony builds their stuff to last, even after beiung abused.
Posted on Dec 29, 2008
4 Suggested Answers
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
  • 23 Answers
SOURCE: Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Posted on Jul 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
Posted on May 21, 2010
Testimonial: "@dunnbiker Very true on assumptions! I've tried everything the manual suggests. Right now, nothing is connected to the unit, but upon power up, I get the SP:OFF display (which is not seen in the DEMO mode). I will try the headphone jiggling idea and see what happens."
Problem turning unit on
it may have an internal shout somewhere causing the speaker protection relays to kick out..
Jan 18, 2014 | Sony STR-DE935
Power Problem with Fisher RS 9015
Glad it helps, thanks also for choosing Fixya for assistance!
Aug 13, 2012 | Audio Players & Recorders
Hi I purchased a sony av amplifier model STR-DB930 on e-bay a few months ago and I am using 3 ohm speakers from my old surround sound system. The output selector on the back of the unit is set to 4 ohms....
The lower number in Impedance specs is not a suggestion. It's a limit. 3 is not between 4 and 8.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DB930-Receivers-manual/id/387bh934/t/2/
If you don't want to buy new speakers, settle for safer low volume levels.
You're going to kill that receiver driving a 3-ohm load. HTS-style speakers aren't reliably re-deployable to other electronics. Perhaps, if you have 4 speakers and they're similar you could wire them in SERIES and present a 6-ohm load to each channel.
Re-engineering the speakers themselves is, well, don't do it. It isn't rocket science but it also isn
Feb 28, 2011 | Sony STR-DB930 Receiver
MY THIRD ROOM HAS NO SOUND COMMING FROM IT WHEN THE SWITCH ON THE FRONT PANEL IS TURNED ON
Had same issue, found out it only uses RCA jacks, no optical input will feed to 3rd room. Bummer
Jul 01, 2010 | Sony STR-DA5ES 6.1 Channels Receiver
Recently cleaned unit. now i am getting arcing on
The arcing sound comes from a loose fit. You may have to bend the contact bar so it fits tightly against the unit.
Feb 28, 2010 | Ecoquest Breeze AT Living Air Purifier
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WV600 rear projection
sounds like bad CRT, some of these sonys have had defective CRT issues, usually all will come and go sooner or later (all 3 bad), you can pull the speaker grill off(either 2 1/4" screws on bottom or 6 1/4" on back sides) and pull off the Crt box cover (2'X3' piece) and lightly tap the CRT's with tv on, if they flare or get colored streaks in pix they are bad, CALL SONY 800 # and complain, also could adjust G2 (Screen control for color) for short patch. Will need new crts.
Jul 31, 2007 | Sony KP-57WV600 57" Rear Projection...
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Mar 31, 2007 | Sony KV-27FV16 TV
Sony STR-DA5ES 6.1 Channels Receiver Logo
402 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
