Question about Bulova Watch
Silicon radio control watch, what # is the eastern zone
The watch is set at 5 for the time zone is this the eastern time zone?
  • 2,334 Answers
It depends which way you are looking at- West or East.
5th time zone on West is for: Greenland, Canada, USA, Bahamas, Jamaica, Columbia, Peru.
On East: Russia, Kazakstan, Uzbekistan, Afghanistan, Pakistan, India, Maldives.
I just do not understand why you do need this. All radio controlled watches are receiving the signal from the place in country where watch is worn- in my case its Rugby in England.
Use your user manual to sort this out.
Posted on Dec 17, 2008
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
How do I adjust the time zone on my E.Howard atomic watch? The T2 button doesn't activate anything when it's pushed?
No, just set properly. This watch is very difficult to set. A watchmaker may be able to help you. The instructions are not very clear. You might try a watchmaker for assistance or try calling them although I have not had much luck along those lines.
Dec 28, 2011 | La Crosse Technology E. Howard Ambassador...
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
Silicon scientific atomic projection clock did no reset for daylight saving. Help
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
May 19, 2010 | Watches
I attempted to adjust the time of my WaveCeptor while out of the country and as a result it is now permanently 1:23 minutes behind PMT. The little LCD windopw shows the correct time, though. I've tried the...
This watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
RECOMENDATION:
You are likely out of range.
Adjust your time manually using the official time link below.
COPY OF YOUR MANUAL:
http://world.casio.com/wat/download/en/manual/
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | Watches
Silicon Scientific Radio Controled Watch
how to change hour number for setting clock back
Feb 05, 2010 | Watches
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 | Watches
How do I set a LaCrosse WT-961 (B) watch?
This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
Hold down the button for 2 seconds until the time zone abbreviation & zone flash the keep pressing the button until your correct time zone is displayed. Then wait about 8 seconds for the watch to return to normal display. Then you just have to wait until it picks up the signal & sets itself. I hope this helps.
Mar 07, 2008 | La Crosse Radio Controlled Watch
Timex T5E881
You have to get in the right time zone, that’s why you are an hour off (and this may also occur if you are in an area that switches between daylight savings time each spring and fall).
Press mode until ZO appears on the watch face.
Press and hold ADJ. Time zone will begin to flash.
Select start/stop or adjust to get to the right time zone P, C, M, E (pacific, eastern, Mountain, central)
If desired , press mode to select DST (daylight savings time) and press start/stop or adjust to turn it on or off.
Press adjust when done.
Nov 10, 2007 | Timex 1440 Nylon watch
Bulova Watch Logo
197 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
