Question about Sony Hi8 CCD-TRV138 Camcorder
Old tapes don't play
I had a Sony DCR-TRV103 camcorder that was stolen. I was recommended to the Sony CCD-TRV138 camera as a replacement. None of the tapes I recorded on the old DCR-TRV103 will play on the CCD-TRV138; all I get is static and noise. I've read online that digital camcorders will not play analog tapes; is the same true in reverse? Do I need to replace my new camera with a digital model? Or is there some switch or toggle or something I need to trigger to get this thing to work? Thanks in advance!
I have the same problems. Makes me mad. I have a years worth of tapes that I can no longer view. My dog at peed on my old camera which was a digital one.
Posted on Jun 20, 2007
SOURCE:
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
My camcorder can play old tapes but won't record
Your camcorder Sony DCR-HC20E has bad ccd imager problem and that part will be replaced to have live view to record on tape.
I can provide you ccd imager part number info if you want to repair it by yourself.
CCD Imager replacement in this camcorder requires expertise and fair skills of soldering parts in PCB.
Jul 11, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
No sound
Dear PITIN,
Camcorder CCD-TRV138 has no sound problem in playback. There can be 02 reasons, One is the defective speaker bultin camcorder or 2nd is defective IC801, (Audio-Video Processor AN12985A-VB). In both cases you sould go to nearest Sony service shop to fix this problem.
May 24, 2008 | Sony Handycam DCR-TRV250E Digital...
HELP
the heads could be dirty or the tape path could be out of alignment.
Mar 16, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
SONY CCD-TRV138 8MM CAMCORDER
CCD-TRV138 Attempted to record or play. Not operating.
Dec 20, 2007 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony Hi8 CCD-TRV138 Camcorder Logo
158 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
