ASUS Terminator P4 PC Desktop
Problem for ASUS Terminator P4 PC Desktop
I have a Sony Unit
By tomamcd on Dec 11, 2008
I have a Sony Unit - with ASUS P450-VX motherboard. I put in a AGP video card in it and it works fine except on cold boot -in POST, The onboard video is used (only on cold boot - once the AGP card is found all warm boots work perfectly. How do I diable On board Video? Is there a schematic or bios update?
Same Problem
Dec 26, 2008
-   Thanks - in windows - as I can see the screen as the unit is using the AGP card, there is only 1 device. The on board Video port is not shown as its not being used by the monitor. My problem is only on a truely cold boot. If I shut off the unit and restart it works fine. If I let it sit over night, the true cold boot Power on self test goes to the on board card and uses it instead of the AGP card. To make matters worse the BIOS does not have a turn off on board or turn on AGP. According to Sony support they do not support AGP but the motherboard has a dedicated slot <good Grief>. -   Guest
Solution #1
posted on Dec 26, 2008
Not Rated)
Loteck
Rank: Wiz
Rating: 82%, 81 votes
I'm not exactly sure what you are explaining but to disable in Windows go to: My computer: Properties: Hardware: Device Mgr: Graphics Card and for the one listed that is not your AGP card click: Disable This Device. It's just that simple. Also, in some BIOS,maybe all, there is an AGP: enable/disable box. This of course should be enabled.
Was this helpful?
Yes
No
Popular Solutions for ASUS Terminator P4 PC Desktop
Questions and Unsolved Problems for ASUS Terminator P4 PC Desktop
Do you recommend ASUS Terminator P4 PC Desktop?
Answer
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Answer
Umax 2200 usb scanner &amp; Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
adr=610c Abort program code error 6193
Answer
My ASUS Terminator P4 came with a 256 MB DDR DIMM installed (unbuffered non-ECC PC2100/1600). I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS Terminator P4 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
