Question about Motorola Mobility Bluetooth??¢ HF850 Car Kit Wireless Headset
On my HF850 poor volume using my Black Berry 8830 (world phone)
When the BB connects i cannot adjust volume on phone (and thereby in my volvo XC90). The volume is able to be adjusted on 8830 otherwise but not when paired with hf850. I have tried adjusting volume up (when call in progress) on hf850 but it is at max. Also tried to adjust default (when no call in progress) but no luck.
I cannot hear.
Worked fine on my moto egg.
  • 2 more comments
  • gord_keith Dec 12, 2008
    Thanks drumbanger...volume limiter on the BB or hf850? I cannot locate on either.
  • gord_keith Dec 13, 2008
    Sorry Fixe_U, can y9u be more specific. The only volume control on the hf850 is up on down when in a call. No audio profiles i can find in the BB menu.
  • gord_keith Dec 19, 2008
    I had a suggestion to check BB phone settings. I am aware of these and made numerous ajdustments to no avail.
    The last suggestion is to check with BB to see if there is a firmware upgrade. I will check but the solution does not seem very easy!
  • gord_keith Jan 06, 2009
    Still no luck to date. I am arranging to take vehicle back to dealer to have blue tooth unit replaced or repaired. just got my invoice from FixYa but have not heard a viable fix yet.
  • 365 Answers
The settings to enable the sound as maximum for the incoming calls can be changed in the call settings menu or the function which is seen along with the call related menu .try to change it from there.thank you
Posted on Dec 19, 2008
  • 470 Answers
Just wanted to let everyone know or at least those inquiring minds concerned about the 8830 vibrate being to weak. RIM developers (my father works for RIM) as a SR. Java Developer and Q/A manager. They needed power for the SD module integrated into the back of the device and they had to sacrifice a few other things as well. I don't know if you guys know this but the 8830 prototypes had webcams and RIM scrapped the idea because of issues with device memory (not talking about space) im referring to device memory as in NVRAM and physical memory. The vibrate issue wont be fixed for another year until the next version of the phone. This sucks but in order for them to add the media components and extra storage the electrical engineers working for RIM had to move things around. RIM isnt going to admit this but it is the truth.
Regarding the volume issue for all 8830 (i have a sprint) my ringer issue actually only happened after the first time i installed an SD card in the back. If you remove the SD card and reset the device without the SD card and run the default ring tones you will notice they are louder. I'm sorry to say that both of these issues have nothing to do with the "firmware" for the device they are issues regarding voltage and the physical design of the circuits. If there are any electrical engineers on this forum they can verify this by simply reverse engineering the device.
Once again its all about poor engineering and not enough adequate voltage going to the hardware.
The may release an upgraded phone or the newer models may fix this issue.
Thats all I really know.
  • 92 Answers
Sounds like issue. go to the cell phones providor and have them look at it i means its free to,
    Master:
  • 479 Answers
Go to profiles>advanced>edit.-----> now how to go to profiles ---------->Depending on theme running, there is a "speaker" icon. It is on the screen that shows all apps. Again depending on the theme, it might or might not be a "speaker" icon but it will show "Profiles" when highlighted.---------------->there you profile set to "loud", change the volume level.also  try to use the master volume on the side of the phone when  it's ringing with an incoming call, . ---------------> keep in mind that ----->You need to go to your profiles. Select Advanced>Edit>Loud. Change the volume of your ringer in there.------------->if this still does not helps-------------->If you know how to get to your profile menu, please do so and open it. Scroll all the way to the bottom and select Advanced. Click on it. Now. You should see a list of profiles: Loud, Vibrate, Quiet, Normal, Phone Only, and Off. Hover over the LOUD profile, click your menu button, and select Edit. Scroll down and select Phone. Set your volume to High. If you do not want your phone to vibrate before it rings, select Tone at the top instead of Vibrate+Tone. ========================= if all this does not helps then  click on this link below How to edit a PROFILE & set NOTIFICATION
Posted on Dec 13, 2008
  • 116 Answers
Check the default call volume level options->general options->default call volume after you set it hit menu and then save.
  • 2,427 Answers
Its proberally a security feature in the phone or an bug in the firmware. You should contact the manufacturer or dealer requesting information on this.
All i can suggest is that you try to update the firmware on the phone. Ususally when the company discovers an error the release a new firmware to correct the problems. Go to the manufactures web page and search the firmware update for your model. (its free and contains everything needed including instructions on how to do it).
If it aint the firmware the only other problem i can think off is a hardware error it self, in this case you will need to have a local dealer have a look at the phone. My best guess is its the firmware.
  • 1,800 Answers
Try to set the proper profiles for each unit and try .
Posted on Dec 12, 2008
  • 19,396 Answers
Ensure that the pairing is configured properly.
Follow instructions on website below:
How to Configure a Bluetooth Headset to Blackberry |
  • Ginko
    Ginko Dec 12, 2008
    Try also the following fix:
    "1. From main menu, select "Profiles" (icon looks like a speaker)
    2. In Profiles, select "Advanced"
    3. Select "Loud" profile
    4. Select "Phone" from list
    5. Under "Out of Holster", select "Volume" (which is probably set at "Medium" from factory) and change to "High"
    6. Repeat Step 5 above for "In Holster" volume setting.
    7. Press Blackberry "Menu" key and select "Save".
    from BlackBerryForums.com
    Scholar:
  • 143 Answers
Dear sir
u have to re pair yr device with surchin thru car kit which give u a button to surch device when it's connected ( paired) then u have set control
Press the volume buttons (C and B) on the car kit to increase
and decrease the volume.
If you press and hold a volume button, the volume is
automatically increased or decreased to the highest or lowest
step.
You can also adjust the volume remotely by pressing the
phone’s volume buttons, if your phone supports this feature
or for more information u need menual and her is electronic menual avalable here ... http://www.starbatteries.com/mohfwiblhaca.html
thanks
please vote
jo_chinmay
Posted on Jan 06, 2009
  • 66 Answers
You may have a faulty unit. I would suggest returning it for a replacement
    Genius:
  • 1,199 Answers
Try going into the menu and turning off the volume limiter! audio!
I have a new bb 8830 world edition phone on a Vodafone GSM network. I have requested for the bb service to be activated. Which the service provder has. Unfortunately, the settings are not received by my BB...
Looks like you just change your original sim card with other network sim card. You must unlock your blackberry first before you can using other network in your phone. What you need is blackberry 8830 unlock code from your original phone network sim card. You can get blackberry unlock code from network provider or buy from third party sites which have lower cost rather than network provider.
May 14, 2011 | RIM BlackBerry ® 8830 Cellular Phone
Verizon's BB 8830 World Ed. on Telus?
Yes why not, if you want to unlock it i suggest you go to BlackBerryMEP.COM , they will send you your unlock code within minutes along with a full detailed guide on how to input the code using the keypad of your BlackBerry 8830 .
Jul 16, 2009 | RIM BlackBerry 8800
Unlock sprint BB 8830 world edition
if it is unlocked u can go for any service,blackberry supports both cdma n gsm.for unlocking contact blackberry service station which is in pune
Jul 02, 2009 | T-Mobile Sidekick II
Bb volume in call...fluctuating
you need to reflash you OS on to the phone...
you can connect the phone using the usb cable to the laptop/pc/mac that you are using then open your desktop manager (blackberry).....open apploader then click on software update and upload the OS back to the phone this should work..and you should be good to go.
May 09, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Blackberry 8830 - World - Problem Pairing with Bluetooth
I am having the exact same problem and cannot seem to resolve it; have you had any luck over the past month?
Mar 06, 2009 | RIM BlackBerry ® 8830 Cellular Phone
I arrived in So. Africa on Monday. My Blackberry 8830 will not turn on. It was fine when I left JFK. The screen is black and the light flashes red. I cannot use the Blackberry Message Center on my...
It is because the black berry has some features that it has a lock which activates when you leave any country. Your phone will start working again when u will get back to JFK.
Feb 12, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Telus Blackberry 8830 World Edition with Rogers SIM?
Unfortunately, you can't use the current Storm model on Rogers. The Telus network is CDMA (Rogers is GSM), which means Telus' wireless products do not use SIM cards :-(
If it's any consolation, there is supposed to be a Blackberry Storm released soon that will use SIM cards and could be used on Rogers.
Dec 28, 2008 | RIM BlackBerry 8800
Black Berry 8830
you can get it for $49.99 here: http://www.gsmunlocklabs.com/unlock-blackberry-c-56.html or here: http://easygsmunlock.com/unlock-blackberry/
Aug 23, 2008 | RIM BlackBerry 8800
Motorola Mobility Bluetooth??¢ HF850 Car Kit Wireless Headset Logo
325 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
