Question about Maytag Atlantis MDE7400AY Electric Dryer
Removal of the top on a maytag model 7600.
I found the relase pins and pushed and yet the top does not budge? Want to check the belt, it seems to jump of slip when starting.
  • 65 Answers
TO GET THE TOP OFF, YOU MUST REMOVE THE FRONT PANEL BY TAKING OUT THE TWO SCREWS BY THE DOOR HINGES AND THEN THE TWO ON THE OPPOSITE SIDE. THEN REMOVE THE FRONT PANEL. THE TOP IS HELD DOWN BY TWO METAL HOOKS THAT ARE SECURED BY ONE SCREW EACH. THIS SHOULD GIVE YOU ALL THE ACCESS YOU NEED TO CHECK THE BELT.
Posted on Jan 27, 2009
Cabinet removal maytag dryer 7600
Go to www.repairclinic.com and enter 7600. You will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly.
Feb 24, 2017 | Maytag Dryers
Maytag performa stops during agitate or spin
All washers have a safety switch on the on lid. There is usually a slot that a plastic pin goes into to activate the switch. These switches are high failure parts. The switch is located on the underside of the top deck. It should check 0 ohms when closed. You can also jump it but then it would NOT stop when the lid is open ie; during agitation or spin cycle ( a safety hazard).
Sep 01, 2012 | Maytag Washing Machines
How do i change the belt on a model No. DE308 maytag dryer
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
Won't spin at end of cycle. Maytag top load washing machine
RITS REAL COMMON WITH THAT MODEL FOR THE BEARING TO LOCK UP. TURN THE TUB BY HAND A LITTLE THEN TRY SPIN, IF IT THEN RUNS YOU NEED A BEARING/SEAL KIT.GOOD LUCK
Jan 16, 2010 | Maytag SAV5710 Top Load Washer
Loose tub on maytag 7600 electric dryer
the tub bearing needs to be replaced it is on the back center of the drum
Apr 20, 2009 | Dryers
Puritan watch link removal
its sound simple enough but you will need to use a bit of force to budge the pin.
you will need
blue tack
punch
pin hammer
pliers.
Roll up the blue tack push onto flat surface , push the barcelet side on into the blue tack wthe arrows pointing downward.
insert the punch into the hole and tap with hammer.
do this until you have removed enough links then push a pin back into the bracelet and tap home withthe hammer.
Aug 25, 2017 | Lucien Piccard 26024 Wrist Watch
Maytag Atlantis 7600 spin cycle (top load)
the maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Sep 04, 2007 | Maytag MAV7600 Top Load Washer
Maytag Atlantis MDE7400AY Electric Dryer Logo
136 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
