Question about Kenmore 63942 Dryer
Connecting 279769 what wires go where???
Just got parts in Thermal Cutoff pack. Not sure which prong the red and black wire need to connect to..how can you tell???
  • wymy Dec 26, 2008
    It would have been helpful if you shared your answer. :(
I think that, because this is a fuse, it does not matter which it's connected to. Essentially it closes the circuit between the wires and if it gets too hot, it will 'break' the fuse. In any event, I plugged my black wire to the bottom and the red to the top. I'm not sure what defines top or bottom other than the floor and ceiling of the dryer itself. I searched all over the place for an answer to this, but ended up just going with the fuse logic.
Posted on Dec 26, 2008
Just figured it out on my own...
Posted on Dec 11, 2008
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
Feb 04, 2011 | Maytag Dryers
Hi, I have a probLem! No doubt you hear that frequently!! First, you need to know I'm 60, and not a mechanical or electrical bone in my body. I found this site as I was looking for a heating element for...
The two red wires on the dryer probably connect to the short red/wht wire at the end with the extra connector. The other end of the red/wht wire would then connect to the blk/wht wire with small brass connector. This arrangement should place the thermal cutout in series with the high limit (ie, one after the other). Suggest you post pictures if this doesn't sound right.
Feb 27, 2010 | Whirlpool LER8648P Electric Dryer
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
Dryer is turning but no heat is coming out
If you had a 3 prong originaly you probably have only 3 wires to work with, either a red and black and white or a black and a black with a red stripe and a bare stranded wire. The black and red are ALWAYS the 2 hot wires 230 volt. The white or bare are the neutral / common wires. If you only have 3 you will need to get your equipment ground from a cold water line to the 4th prong.
Another option leave the 3 prong in the wall and install the old 3 prong pig tail on the new dryer then ground the frame of the dryer to the nearest cold water line. The water line must be metalic for this to work.
Dave
Mar 15, 2009 | Whirlpool Dryers
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
