Sunbeam electric blanket flashing ff when I try to turn it on.
  • 5 more comments
  • Anonymous Dec 23, 2008
    My sunbeam blanket will work fine for a while then will begin to flash. I have to unplug the blanket and replug to get it to stop flashing.
  • Anonymous Dec 25, 2008
    Sunbeam electric blanket flashes FF. How do I get it to stop?
  • Zeusest Dec 29, 2008
    So do I... How do you fix it? The blanket does NOT get warm when it flashes. And, it's out of warranty. What do I do?
  • Anonymous Jan 19, 2009
    Same problem here. I have a King size model with two controls that I bougth from Costco. Only one of the controls, i.e. only one side, stopped working and is displaying the FF.
  • Anonymous Jan 21, 2009
    Mine does the same thing. Won't work at all. This is really crappy considering it's 3 degrees outside and my house doesn't hold heat well in the winter.
  • Chilly Carol Feb 22, 2009
    Same problem. It flashes FF and won't heat up. Sure hope someone can point us in the right direction
  • Anonymous Mar 22, 2009
    Same problem - both control pads flash FF.  No changes despite being left unplugged for a month.
Ok folks. I fixed it. I unplugged and then waited and replugged and started at high or 9 and then it went to FF in 60minutes or a couple of minutes. I scratched my head and tried this fix--instead of starting again at 9 or H I started at level 7. That did it. FF most probably indicates excess current, and the H or 9 probably is too high to set. So unplug -repluf-turn on and dial 7 or lower. It should fix it. Or buy a new one.
Posted on Nov 21, 2010
I came here with the same problem but after finding no answers I checked the connection to the blanket and discovered that mine is unplugged! Check your connections and while you are at it make sure the wires aren't pinched or tucked under the mattress ( not an expected cause but things to be avoided for safety's sake). See if you have a bad connection or even mismatched controls.
Posted on Mar 30, 2009
I also tried pushing and holding the on/off switches, both at the same time, for 3-5 seconds. It worked!
Posted on Jan 12, 2013
  • David Sowby Jan 12, 2013
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Electric blanket won't stop flashing
FF- loose contacts wiring. check all fuses and also wiring to your unit.
Posted on Dec 26, 2010
Rinnai ex 38 flashing code 99. I took the vent apart and there is no blockage. Unit has only been installed one month.
If it is only one month old doesn't do anything but call for warranty serving. ANY attempt to repair this will void the warranty.
Jan 10, 2017 | Rinnai Heating & Cooling
How do I disassemble a central heating unit. To take it out
of course it depends on the type . Gas or electric . were we there able to see it . perhaps we could be more helpful . turn off electric at the mains turn off the gas at the outside shutoff . and lock both in the off position . it depends on where you live if you are required to get permits to do this also . or if you have to hire professionals .
Jan 07, 2017 | Heating & Cooling
Mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
Jan 05, 2017 | Mitsubishi Heating & Cooling
How do I fix my electric heater
  • sounds like the sensor or bulb that tells it to start the blower is defective/ im not familiar with your unit but this seems the most logical answer most furnace will not turn the blower on right away usually 90 seconds after the ignition but will also run longer to exhume any dangerous carbon monoxide. Electricic heaters are different. What type of unit do you have
Dec 25, 2014 | Heating & Cooling
Why does my ceramic heater keep turning off
Without other specifics I can only postulate that it's more than likely overheating, and perhaps it's location stifled
Dec 09, 2014 | Heating & Cooling
Electric Furnace stopped running
You have one of two problems. Either the capacitor for the motor has failed or the motor has failed. I would turn off the power to the unit and see if you can locate the capacitor and remove it. An ac supply or electrical supply house can match up the capacitor. This is relatively inexpensive. Otherwise you will need a new motor.
Nov 11, 2014 | Heating & Cooling
Ac will not turn on. Once I pull the face it will work but if I try to turn to another setting it turns off again. Help
Hi Aaron,
You need a new thermostat, they are not very expensive and they are easy to install...
Oct 24, 2014 | Heating & Cooling
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Nov 28, 2013 | Heating & Cooling
Flashing re co
Re Co stands for Recovery Mode. That means if you have programed your thermostat to be at say 72° at 5:00 then it should kick on in Recovery Mode several minutes before 5 in order to reach that temperature. This is normal and doesn't indicate that something is wrong, just that your thermostat is trying to reach or recover the programed temperature.
Feb 08, 2008 | Heating & Cooling
Heating & Cooling Logo
3,681 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
