Question about Daewoo Televison & Video
Model# DTC-20V1TM I need a code or remote - Daewoo Televison & Video
  • 275 Answers
DTC-20V1TM(sm) DAEWOO-5
Posted on Dec 11, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try here for a possible replacement remote for the Daewoo DTC-20V1TM.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 11, 2008
    Or you can post back the brand and model of the replacement remote you are currently using or intending to use. Thereafter we can figure out if it is compatible and if a programming code exists.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Genius:
  • 1,269 Answers
You can get the code from the manual that came with it.
  • Michael Galve
    Michael Galve Dec 11, 2008
    You can call the number below if you wanna order a remote replacement.
    0044 121
    2408440
DTC remote rc16 code for Magnavox mwc13d6
If the DTC remote is not universal, it cannot be used.
Nov 30, 2016 | Magnavox Televison & Video
RCA REMOTE CODE FOR APEX DTC
Check these codes. 10156, 10748, 10879, 10765 If you wish to get more, check this link.
Feb 08, 2013 | RCA Televison & Video
Hi i'm need the codes for a RCA converter box i'm
Check these codes:
RCA HD65W20 ............................ 0658
RCA PSHD105 ............................. 0636
RCA DTC-100 ............................... 0636
RCA DTC-210 ............................... 0636
Oct 19, 2012 | Televison & Video
I want to program my greenbrier 6 in 1 remote to my rca digital converter box
These are the setup codes by model.
Oct 18, 2012 | Audiovox Universal Remote, NaviLight 6, 1...
I need codes for rca converter box remote
Aug 24, 2012 | RCA Universal Remote Control
Need remote code for rca converter box
Apr 18, 2012 | RCA Televison & Video
I need the code for an RCA DIGITAL CONVERTER BOX FOR MY PHILIPS SRP5107WM/17 UNIVERSAL REMOTE
Apr 10, 2012 | Philips Televison & Video
I need a wiring diagram for the IPC in a 2004 Cadillac Deville. Trying to troubleshoot a U0155 OBDII code. The symptom is that my climate control display only shows LED's intermittantly. All of the...
Do you know what U code's are for ? How did you pull this code ? There is no U0155 , U code's start at
Diagnostic Trouble Code (DTC) List
DTC
Diagnostic Procedure
Modules
U1000
DTC U1000 and U1255
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC, IPM, LMDM, LRDM, MSM, PCM, Radio, Remote Playback Device CD Changer, RCDLR, RIM, RMDM, RRDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1016
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC , IPM, LMDM, LRDM, MSM, Radio, RCDLR, RIM, RRDM, RMDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1040
DTC U1001-U1254
IPC, PCM, SDM
U1056
DTC U1001-U1254
EBCM, PCM
U1064
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC, IPM, LMDM, LRDM, MSM, PCM, Radio, RCDLR, Remote Playback Device CD Changer, RIM, RMDM, RRDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1065
DTC U1001-U1254
DDM, DIM, ESC, FPDM, IPC, LMDM, LRDM, VCIM, HVAC Control Module - Auxiliary, PCM, Radio, RIM, RMDM, RRDM, VCIM
U1066
DTC U1001-U1254
DDM, FPDM, IPC, IPM, PCM
U1088
DTC U1001-U1254
IPC
U1096
DTC U1001-U1254
PCM, SDM
U1128
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, Digital Radio Receiver, Remote Playback Device CD Changer, VCIM
U1129
DTC U1001-U1254
Radio
U1130
DTC U1001-U1254
Radio
U1137
DTC U1001-U1254
Radio
U1144
DTC U1001-U1254
IPC, Radio
U1151
DTC U1001-U1254
Radio
U1160
DTC U1001-U1254
IPC, RIM
U1161
DTC U1001-U1254
IPC, RIM
U1162
DTC U1001-U1254
IPC, RIM
U1163
DTC U1001-U1254
IPC, RIM
U1164
DTC U1001-U1254
DDM, Digital Radio Receiver, DIM, FPDM, IPC, LRDM, MSM, VCIM, Radio, RIM, RRDM, Steering Column Module
U1165
DTC U1001-U1254
DDM, FPDM, LRDM, RRDM
U1176
DTC U1001-U1254
IPC
U1192
DTC U1001-U1254
IPC, PCM
U1255
DTC U1000 and U1255
U1300
DTC U1300, U1301, or U1305
U1301
U1305
The data link connector (DLC) allows a scan tool to communicate with the class 2 serial data line. The serial data line is the means by which the microprocessor-controlled modules in the vehicle communicate with each other. Once the scan tool is connected to the class 2 serial data line through the DLC, the scan tool can be used to monitor each module for diagnostic purposes and to check for diagnostic trouble codes (DTCs). Class 2 serial data is transmitted on a single wire at an average of 10.4 kbps. This value is an average; class 2 uses a variable pulse width modulation to carry data and depending on the message it may operate faster or slower. The bus will float at a nominal 7 volts during normal operation. Each module can pull this lower during the transmission. The bus is not at battery positive voltage or ground potential during normal operation. When the ignition switch is in RUN, each module communicating on the class 2 serial data line sends a state of health (SOH) message every 2 seconds to ensure that the module is operating properly. When a module stops communicating on the class 2 serial data line, for example, if the module loses power or ground, the SOH message it normally sends on the data line every 2 seconds disappears. Other modules on the class 2 serial data line, which expect to receive that SOH message, detect its absence; those modules in turn set an internal DTC associated with the loss of SOH of the non-communicating module. The DTC is unique to the module which is not communicating; for example, when the inflatable restraint sensing and diagnostic module (SDM) SOH message disappears, several modules set DTC U1088. Note that a loss of serial data DTC does not normally represent a failure of the module that set it.
Your best bet ,take it to a qualified repair shop.
Jan 01, 2018 | 2004 Cadillac Deville
Need to program remote, don't have codes
RCA TV/VCR Combo Model T09085:
Comcast Digital Adapter Remote (DTA) Code is... 00000
Comcast Universal Remote - Red OK/Select Button (DTC)
Code is... 21479. This code controls TV On/Off and VCR All functions. I could'n find code for vol+/vol- and mute.
Oct 23, 2009 | Televison & Video
Televison & Video Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
