Question about JBL S120PII Subwoofer
Cant get 4000 watt lanzar amp turned on
Ok well the only way i can get my 4000 watt lanzar amp to come on and work is by connecting the power cable into the remote terminal on the amp at the same time as the remote is hooked in. If anyone knows why that is i would really appreciate it. this is killing me , i need to know what is wrong with it??? thanks alot
They're bridged together to get power...idk why it's like this but it was like that on my TIS 1800 for the life of it and i had to remove the fuse to turn it off since i had no ignition wire to the head...just bridge the remote with the power and u'll get power and it'll work fine
Posted on Nov 05, 2009
Just find a new remote man the one you have is messed up..that why it wont turn on...
Posted on Sep 05, 2008
It sounds like the posotie side of your amp is bad or the soder point is broken
Posted on Aug 12, 2007
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
How do i reset my 4000 watt lanzar vibe 286 from being in protect mode
You can only reset it by disconnecting power to it. If it is in protect you may want to check your speakers and speaker wires for shorts and/or grounds. If they check out all right you may have internal problems in the amp.
Oct 28, 2011 | Lanzar VIBE286 Car Audio Amplifier
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
My lanzar 1600 watt amp wont turn on at all why
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you. Might be time to invest in a new amp. lanzar-1600-watt-amp-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 12, 2011 | Lanzar VIBE266 Car Audio Amplifier
I have a lanser 4000 outputting loud engine noise
Double check your connections. Sounds like you are picking up alternator whine. Make sure the rca cable is at least 12" away from power and remote cables when installing fem radio towards amp. Its best to runthem on opposite sides.
.A thumbs up would be greatly appreciated if this answer is helpful to you. lanser-4000-outputting-loud-engine-noise-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jul 17, 2010 | Lanzar MXA282 Car Audio Amplifier
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
My vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
JBL S120PII Subwoofer Logo
171 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
