Question about Savin 9935DP Laser Printer
SAVIN AC104 says there is no paper but there is
YIKES--got to give a speech and when paper ran out, I put in new batch but now indicator says there is no paper. I have turned printer off and on twiceand inserted and re-inserted paper drawer, changes types of paper. . . now what?
  • Anonymous Dec 15, 2008
    I have the same problem i was printing and then suddently it said there was no paper. I checked but there was still some left so i just put more in and made it neat and line up before i put it in. Then i tried to print again but its still says non paper.
    New Friend:
  • 34 Answers
You may have broken the add paper sensor or actuator.
Posted on Feb 18, 2008
Savin c3210 keep jamming paper just before the output tray
Use alcohol to clean all the rollers in path of paper. Make sure there are no obstructions.
Aug 28, 2017 | Savin Office Equipment & Supplies
Paper jam reset
make sure all access covers are closed...if they are then there is still paper somewhere inside the machine
Jan 19, 2014 | Savin Office Equipment & Supplies
Verfione vx510le keeps saying it is out of paper
There is a problem with the paper detection mechanism. On a batch run, the setting can drift over time causing a false indication of no paper. Unfortunately, batch runs have to be monitored; the set-it-and-forget-it approach is not reliable. This is a frequent problem with batch runs on copiers as well
Jul 19, 2013 | VeriFone VX 510LE Terminal w/Internal PIN...
We have an Savin Copier 816 which has an error message to load paper. There is paper in the tray.
Hello!
If you are sure that there is paper in the tray the problem is in the papaer sensor.
It maybe broken or out off the place.
Take the tray out and look inside. Maybe you see the sensor out off the place. If so just put it gently in the place.
Hope this helps you.
See you!
Aug 29, 2011 | Savin Office Equipment & Supplies
My SAVIN 2575 is giving error code sc820, any idea what the problem is ?
Unfortunately, I've never seen this error, so I can't give you much help beyond what the code means and the possible solutions that the service manual provides...
SC820:
Self diagnostic error: CPU - Unexpected external error or interrupt occurred.
• Controller board defective
• Software defective
The manual indicates this is a "C" type code, so this should not be displayed on the OP panel, only logged in the SC history in the machine.
Jun 23, 2011 | Savin 2575 Black and White Copier
Star TSP400 label printer Hi, have the following problem: Just put in new paper roll. Now all red lights are on, beep sound indicated that something is wrong and I get no response at all when I want to...
I had the identical problem recently with a new batch of ticket stock in a TSP400. It was eventually solved by cleaning the roller at the front of the print-head with alcohol (surgical spirit).
The roller had no visible dirt on it but may have been greasy, and the feed mechanism is clearly very sensitive to such things. It turned out that our ticket stock had been recently re-sourced and the new paper was slightly smoother than the old.
CEM London
Aug 10, 2010 | Star Micronics TSP400 Label Printer
Scanner locked
Disconnect the printer and leave scanner cover open (when printer is disconnected.) When connecting printer after 10 minutes shut the scanner cover before turning the printer back on and putting the plugs back in.
Aug 31, 2009 | Ricoh AC104 All-In-One Laser Printer
Receiving fax but not printing ricoh ac104
  1. check paper
  2. check modem, rj 45 may be in wrong slot, must be in "line" not "tel"
There are no error codes????
http://www.websitetoolbox.com/mb/copierquestions
Dec 15, 2008 | Ricoh AC104 All-In-One Laser Printer
Savin 2527 indicates toner empty
i would suggest make sure the toner is the correct type, make sure when you install the cartridge it is tilted a little so toner will be towards the cap.
change your photoconductor unit.
Jul 19, 2008 | Savin Office Equipment & Supplies
124 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
George Mclaughlin
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
