Question about Xerox DocuColor 12 Printer
Not getting true blacks from my printer who uses this machine
Can you advise in what format I should be sending them to the printer
she seems not to know
except she says she usually uses CYMK, if I convert my files to CYMK
will I get a better color representation?
These images are photographs
thanks
Print Some Pure Patches only and check your developer first.
Posted on Dec 11, 2008
While scanning using my SCX-4300 laser printer, I get black bands/stripes in the middle of the scanned image. I tried to use another PC to check problem with my original PC. But the same problem got...
I would look at cleaning the printer glass where your documents are scanned first, if it doesnt resolve problem the printer might need a clean throughout and unless your adept and confident it should be done by someone who is.doesn't take much to upset the workings of these machines.
Aug 16, 2017 | Samsung Office Equipment & Supplies
Black pages received when faxing to others
Your scanner array is bad. This is a light "bar" that lights up to scan your originals before they are sent out. You can test for this by making a copy with your machine. The same scanning function is used to make a copy as it is when you scan to send a fax. If you make a copy and it comes out black then your scanner is bad. This is especially true as when you say that the problem goes away for a short time after turning the machine off. This allows the circuit to cool and the solder connections to shrink and make contact. As the board heats up the metal contacts expand and "open up", causing the scanner to fail.
Not a cheap fix unfortunately.
Good Luck and Thank You for using Fixya.
Mar 16, 2010 | HP LaserJet 3050 All-In-One Printer
When we select Scan to File and choose pdf file format, what we get is a file with a pdf extension, however, it is not a true pdf file. We cannot use Adobe Reader search feature. It seems more like a...
Correct! Its a PDF but its just a picture of the characters you will have to OCR it to use the search feature. Good Luck  E-Copy is a good program for doing this or Laserfish
Apr 30, 2009 | Toshiba Office Equipment & Supplies
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Mar 19, 2009 | Brother MFC-9440CN Laser Printer
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer not printing - showing 'processing' but nothing happening
Reinstall the driver again, if it doesnot work, you have to update the firm ware of the machine, you can find this on kyocera website.
Nov 25, 2008 | Kyocera Mita KYOCERA/MITA - FS-2000D Mono...
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Press Enter to Align Cartridges
Question: when last was it serviced?
Do you use org. consumables?
By the sound of it the printer needs a service, the shaft and carriage seems to be dry and needs some lubrication
Apr 16, 2008 | Office Equipment & Supplies
Xerox DocuColor 12 Printer Logo
41 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
