Question about Mitsubishi VS-45607 45" Rear Projection Television
NEED TO REPLACE BULBS IN mITSUBISHI VS 45607 cAN NOT FIND THEM
RECENTLY GOT A USED VS 45607 AND tHE TV TAKES ABOUT AN HOUR TO WARM UP AND START WORKING PROERLY tv REPAIR SAYS NEED NEW BULBS OR LAMPS, sO i TRYED TO REMOVE ONE FOR PART NUMBER NEEDLESS TO SAY, NOT MY SMARTEST MOVE EVER. lOST ALOT OF FLUID OUT OF tOP PORTION OF LENS ASSEMBLY, cAN YOU BUY THE LIQUID AND REFILL OR NOT AND, i HAVE SEARCHED THE INTERNET FO HOURS LOOKING FOR THESE BULBS AND CANNOT FIND THEM ANYWHERE ANY HELP WOULD BE GREATLY APPRECIATED tHANK YOU
    Genius:
  • 1,199 Answers
This doesent sound like a bulb problem to me at all! it sounds like a few capaciters need replaced! Look put the screwdriver down and call a pro because you could ruin the set trying to do a minor fix and causing a major problem!
Posted on Dec 11, 2008
Mitsubishi VS 45607: 1. TV starts out as B/W when first turned on. After about 30-60 min, the color is restored, although not in the full color spectrum. 2. TV flickers a lot vertically. After about an...
You have a bad video board. If you can find one used it is fairly easy to replace once you get into the TV itself. Your color guns could also be adding to this problem. I am not familiar with this television and its components so I dont know if you can replace one color gun at a time or if once one is shot then all three have to be replaced. That should be a start for you anyway.
Feb 25, 2011 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607
Good Day, rmorales;
Does the buttons on the front panel work properly? I would suspect a bad button assembly.
I hope this helped, good luck, big IRISH.
Jul 22, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi TV VS-45607
Good Day;
This model is known for the front control panel going bad. You could unplug it, control panel cable, from the front of TV, by removing the speaker grill, and just use the remote.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV keeps shutting off
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Apr 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Picture has horizontal lines that move to middle of screen........
Just got this fixed. The problem is the 21 (yes, 21) main capacitors. It'll only get worse if they aren't replaced. The whole screen'll start jumping, multi-hour "warm up" times until you get a clear picture, maybe not even then... it isn't pretty. Just nip it in the bud now, and more power to you if you tackle it yourself. A good repair shop ought to be able to do this for under $400 if you can't.
Nov 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
Jan 24, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
