Question about Frigidaire Kitchen Ranges
It take a long time for my gas range to pre-heat
It takes over 30 minutes for my frigidaire gas range to pre-heat, It appears that everything is ok other than the amount of time it takes to pre-heat. What do you think is wrong?
  • 3 more comments
  • anclacour5 Dec 11, 2008
    For example At 5pm we set the oven at 400 and now at 6pm it is still pre-heating.
    I have checked the burner, its clean and has a distinct blue flame. The broiler works great.
    its obvious the oven is reaching the desired temp. but it doesn't know its at the desired temp!! does that help clarify the problem?
    This would be helpful information if the oven wont heat properly, but if you read my comments when I tried to clarify whats going on you would understand its not a temp issue. It's more like a issue of communication from a thermostat or sensor to the oven display.
    Although the display indicates it's pre-heating the oven is at the desired temp. long before the oven display acknowledges.
  • which temperature are you pre heating the oven.
    Habit-Forming:
  • 171 Answers
The oven flame seems to be to low, that flame most be at least 2 inches long. not counting the sides of flame from one side of the burner to the other, but from where the flame begins at the metal of the burner.
Posted on Dec 11, 2008
  • the oven has a orifice that can be open in side the oven, where the burner sits on the jet goes inside of the burner about half inch turn that jet counter clockwise, turn it a half a turn with the oven off and then try the oven and see if flame when any bigger, if not turn another half
  • Marie Siravo
    Marie Siravo Dec 12, 2012
    My oven also takes long the flame is yellow and it makes my kitchen smell of gas what is up there? had a repair person out even called my local gas provider, they said dont use it thats obviously not the answer.
Frigidaire gallery stove
Hello Debbie - Sounds like the unit has loss some of its heat inside of the oven cavity. This means it cannot reach the proper preheat temperature in the programmed 30 minute timeframe. A technician would be required to further diagnose this concern. They would most likely assess the convection heating element, thermal cutout, thermal oven sensor and all wired connections for repairs. Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat. At t his time, I would recommend contacting a professional to assist you further.
May 24, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My Frigidaire electric oven only heats up to 100 degrees. Please help?
Contact a technician. The ignition and gas valves should allow the unit to preheat and then reach needed temperature within about 30 minutes, at the most.
Aug 22, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Takes too long to pre-heat and emits strong gas odour
This is a serious fire hazard. Replace the THERMOCOUPLE / IGNITER assembly, or call a Repair Service ASAP
Dec 06, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Taking a long time to heat up
sound like you may have a burnt fuse causing to run on half voltage check your fuses thanks from gilles
Mar 14, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire lp gas oven
YOUR OVEN GLOW IG NITER IS SUPPOSE TO STAY ON THAT'S NORMAL. WHAT YOU NEED TO DO IS CHANGE THE ORIFICES ON YOUR OVEN VALVE BECAUSE YOUR USING LP GAS MOST OVENS COME NEW SET UP FOR NATURAL GAS ALL OF THEM EVEN YOUR COOKTOP
ALSO
May 22, 2008 | Frigidaire FGF376 Gas Kitchen Range
Smell Gas
IT APPEAR THAT THE OVEN IGNITOR IS WEAK .YOU NEED TO REPLACE THE OVEN IGNITOR
Dec 29, 2007 | Frigidaire GLGF376 Gas Kitchen Range
Oven takes a very long time to heat.
Do your burners work ok when the oven is on? if not you may have low supply pressure to your range or the regulator may be limiting the gas flow. Also, I have a wolf gas range and it takes 30 minutes to heat to 350 as well, haven't timed it to 400. Has it always taken that long? Another thing to check is the door seal. If its not sealing it could cause a long preheat. If the door seal is smashed flat and/or not soft it needs replaced. Hope this helps.
Dec 16, 2006 | GE Spectra JGBP30 Gas Kitchen Range
Kitchen Ranges Logo
398 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
