Epson Stylus Color 670 InkJet Printer Logo
Posted on Jan 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My old epson stylus color 670 and vista
Recently i bought my new PC (core duo,etc) with vista. i plug in my old epson stylus color 670 printer, but to my amazed, my pc did not recognize it. is there a way if i can still use this printer for my vista? thanks for all your replies. i searched on downloadable drivers for such, but to no avail.
  • Anonymous Apr 25, 2009
    i have a hp notebook with vista, my printer is epson stylus color 670. nothing works or some error
  • Dick Monti
    Dick Monti Jan 18, 2018
    https://epson.com/Support/Printers/Singl...
Dick Monti
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 344 Answers
  • Posted on Jan 18, 2018
Dick Monti
Master
Level 3:
Dedicated:
Answers
344
Questions
0
Helped
448395
Points
1153
To get the drivers/support/information for your 670, go here:
https://epson.com/Support/Printers/Single-Function-Inkjet-Printers/Epson-Stylus-Series/Epson-Stylus-Color-670/s/SPT_C301001?review-filter=Windows+Vista+32-bit
Just choose Vista 32-bit or Vista 64-bit (whichever applies).
Microsoft has not supported Vista since April 2017. I would suggest that you at least upgrade to Windows 7, as Microsoft will probably support it until 2020.
Good luck.
5 Related Answers
Anonymous
  • Posted on Sep 19, 2007
SOURCE: Unable to locate R1800 in dropdown menu
After long and frustrating 3 days here's what an Epson expert suggested I do - and it's the only thing that worked: If you're not using any other epson printer, go to HD>Library> and trash the whole EPSON folder If you're are using other EPSON printers go to HD>Library> and look for the "xxxxxx.plugins", where xxxxx is the name of your printer. Trash it! Then go to HD>User>"ussername">Library>Preferrence, "ussername is your login name to your computer. It's in a folder form. Delete anything w/ a COM.APPLE.PRINT. prefix(i.e: COM.APPLE.PRINT.PLIST or COM.APPLE.PRINT.PRINTSERVER) Restart your computer and after that empty the trash. Download the driver for your printer from www.support.epson.com to install the printer and install it. Under the PRINTERS heading select INK JETS and then the Stylus Photo R1800. Under the DRIVERS & DOWNLOADS section select MACINTOSH. Select and download the following file: Printer Driver v3.0aAs Intel-based Macs with OS X (v10.4.4 or later) epson11769.dmg Install this by clicking the epson11769.dmg icon on your desktop run the installer icon as soon as install is complete hit quit and restart mac go to printer setup utlity and add the printer do a test print from word editting applications(like text edit or MS word for mac) b4 printing go to file> page set up and change the "format for" top the R1800 click ok then go to file and PRINT
Anonymous
  • 162 Answers
  • Posted on Nov 24, 2008
SOURCE: EPSON Stylus Photo R1800: InDesign CS3 (iMac 10.5.5) colors wrong
You definitely need to use the updated driver for Intel Macs.
Anonymous
  • 27 Answers
  • Posted on Sep 04, 2009
SOURCE: my cartridge
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
apppp17
Anonymous
  • 1566 Answers
  • Posted on Nov 08, 2009
SOURCE: is Epson stylus color 670 compatible with Windows
Hi there Enigma,
Im afraid Epson is yet to launch the driver for Epson Stylus Color 670 for Windows 7. Below are the supported OS for Windows:
http://www.epsonstylus.com/cgi-bin/Store/support/supDetail.jsp?oid=14371&prodoid=9936&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=13&y=10
Testimonial: "Thank you very much for your quick answer!!! "
Anonymous
  • 446 Answers
  • Posted on Jan 08, 2010
SOURCE: Epson printer not working with Core 2 Duo
printing with the processor type and speed has nothing to do with printing capabilities, you need a driver that rightly correspond to your Operating system, say Vista, Windows XP, or Win 7
kindly check this area, and install the appropriate driver.
hope this helps
My epson 670 will print a test page correctly ,but when I set it up to print Photos [6 by 4] with fit to size ticked , the printer photo seems to be compressed lengthways, even though there is space left...
Using a combination of the ratio in resizing the picture and after trying numerous combinations of settings ,I stumbled upon a setting which, and after removing the fit to page tick , solved the problem. I think I'm getting to old for this .Thanks
Epson Color Stylus 400/Windows7 Desktop will not"talk" to Printer Printer check per manual is okay Documents queued up to prinb but nothing happens What do I check? Gazza
If it's the same one that I know, that printer is far too old. Epson does not have any drivers for Windows 2000, XP, or Vista, let alone Windows 7.
You will need a new printer my friend.
2helpful
2answers
Is Epson stylus color 670 compatible with Windows 7
Hello there...
It doesn't choose an OS. It's PC and Mac compatible.
My epson stylus color 670 prints goobley gook
Many older printers want to finish a print command before allowing resetting to normal printing, and will ignore your cancel print command in My Computer/Control Panel/Printers/Properties. So either let it finish by feeding used paper or unplug it, cancel documents and then plug it in with the power and feed buttons pressed at the same time to reset. If it will still not print normally despite clearing document print commands and unplugging and resetting, dip switches may be defective or on-board software is corrupted.
My epson 670 won't print with windows vista
hi im josh in cebu phils.friend to solve you problem in printing. you need to check the connections of your printer be sure the cables are mounted prperly on the slot.2nd check the default connections of the printer the port being selected must be the same with the port being used and laslty try to reinstall your printer software driver.thats all good luck hope i helped you.
2helpful
5answers
How do I get my Epson Stylus Rhoto R220 to work with windows vista
I have an Epson Stylus Rhoto R220 inkjet printer for 10 months and i would like to know if its going to work with Vista Windows PC or it won't recognize my printer. How do I upgrade it or get it compatible ?Thaks
Epson RX500
Epson.com Vista Print drivers have just recently 09/13/2007 posted, Download, install, restart, plug printer in. You're Done!
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
