Question about Canon EOS Elan 7ne 35mm SLR Camera
Canon ELAN 7 Battery issue. Camera won't recognize new batteries
All I get is the blinking empty battery icon. It gets enough juice to tell me there is none! Appearently the 4 small gold contacts are not coming up to touch the battery. The chrome center contact sits at least 1/8" above them. I don't know if they are mechanically or electrically raised or if they are spring loaded and just stuck. Any help will be greatly appreciated.
  • jeffrey_ting Dec 11, 2008
    I have tried 3 sets of fresh new batteries. The center contact probably powers the low level warning. Unless the 4 gold contacts are there just for looks, they need some way to raise and contact the battery. Maybe they raise individually depending on need or function. I have always used CR123A batteries. Is there a better battery pack?
  • wldlfnutz Dec 27, 2008
    My Elan 7NE worked perfectly fine with the original batteries. We changed batteries for the first time this summer, and have had the same problem. I purchased "123 Energizer Lithium photo" batteries. The camera indicates it needs 123A, but I have not been able to find those, is there any difference between the 123 and 123A? The first set of batteries I purchased worked when I first put them in, but as soon as I tried to take a picture, the indicator said no battery power. Went out bought a new set, and same thing happened. It seems as if the connection is not right, sometimes if I push down on the battery door, I can get it to show power, take a few pictures, and then the same thing happens. We've been using our old Rebel for now, but would like to use our new camera!
    I plan on taking
    Genius:
  • 1,199 Answers
A new battery will provide enough power to run the camera.....If your battery is not charging right the power will not be enough to run camera ...just the low level warning....which takes very little power to run!
Posted on Dec 11, 2008
Camera will not turn on, even with new batteries
Do you get a flashing low battery symbol? If so, try setting it on P instead of the green rectangle. If it then operates then the shaft in the flash pivot is bent and not operating the flash switch.
Sep 11, 2013 | Canon EOS Elan 7 35mm SLR Camera
I dug up my old Canon Elan 7e and put new batteries in the Vertical Grip Battery Pack BP300, but it's still dead. Anything I can try before bringing in to a camera shop, or selling both the camera and...
Take off the BP300 and put in the appropriate batteries in the camera. If the camera works without the BP300, you know the problem is in the battery pack. If not, you know the problem is in the camera. On eBay, you can replace the camera body for about $35 and the battery pack for about $20.
Hope that helps,
Bax
Aug 05, 2013 | Canon EOS Elan 7 35mm SLR Camera
Canon EOS 300x battery problem: it doesn't work, even with fresh batteries. The LCD battery indicator blinks as they we're dead.
First make sure the batteries are in the correct position/orientation clean both battery terminal and look down inside the battery compartment make sure the "lower" connection is clean (shinny) if not you may need to use a pencil eraser with a piece of sandpaper affixed to it to get down in there and scrub off the corrosion. Another thing and I've run into this myself on a Canon Elan IIe was the battery indicator showed new batteries as dead but the camera attempted too function so, I just used it and used it and withing a few minutes the battery indicator showed the battery state of charge more accurately.
Mar 04, 2011 | Canon Photography
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
New Card
I don't know if this is related to the recording problem, but I believe the red blinking icon may be telling you to replace the backup battery. It's a button-type battery and is located under a small panel located in the area where the LCD folds into, just below and to the left of the buttons there. The battery is a CR1616 battery. Try replacing it and see if it resolves the recording issue.
Oct 30, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Canon EOS Elan 7
I have the same problem!!
Sep 24, 2007 | Canon EOS Elan 7 35mm SLR Camera
Canon EOS Elan 7ne 35mm SLR Camera Logo
215 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
