On a Ricoh FT 4415 copier, what does error ''E2'' mean?
When I turn on my Ricoh FT 4415 Copier, the error message ''E2'' appears. I can't get the copier to do anything.
  • 103 Answers
Hello,Check out this site and see if any of these error codes can help you:
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Posted on Dec 11, 2008
Turn main power switch off then on.If error service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Feb 17, 2011 | Ricoh Aficio 1035 Copier
COPIER RICOH FT 4418 ERROR CODE E 553 what it means appears on switching on. Iam clueless so I havent touched it.
this proplem happened when main motor in machine have big load in his mechanism due to slow movement in units so try check on belts in behind machine
Jan 20, 2011 | Ricoh Office Equipment & Supplies
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Ft 4415 ricoh flahing the magnigication indicator display
That means the machine is due for preventive maintenence, or PM. There is an internal counter that keeps track of the number of copies made. At a preset count, this indicator flashes. Kind of like "it's time for an oil change"
Aug 24, 2009 | Ricoh Office Equipment & Supplies
Error Box on Scree with Error SC-545
Hello sir; According your message, I guess your copier should be Ricoh, any way need to reset your machine, just follow following steps;
1, press "clear mode", "107", and hold down "clear/stop" key until screen change message.
2, turn power off and back on,machine should be in working now.
May 29, 2009 | Ricoh Office Equipment & Supplies
Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Mar 11, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
Dec 17, 2008 | Ricoh Aficio 1035 Copier
373 people viewed this question
