Question about Dryers
We have a new whirlpool duet sport washer / dryer. The screen filter on the dryer has a cloth insert that we need to keep stuffing back in. How do I fix this or glue it back in or replace the filter? Bought at Costco Scottsdale Richard 480 220 8335 cell
  • olso1543 Apr 02, 2009
    Same exact problem here! I am trying to figure out if I can glue it with a heat safe glue or if I can by a new filter somewhere. Apparently this is a common problem?
    Email is olso1543@umn.edu
  • allanpd Apr 11, 2009
    the lint trap fits in properly, with no other way to put it in and usually has a lot of lint at the completion of a cycle.  The problem is that lint is getting past the trap, through the vent and blowing through the wall vent on to the lawn.  Why is the lint getting past the trap...is there a missing part?
No more need..
Posted on Dec 11, 2008
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Whirlpool Duet Sport loud vibration during spin cycle
does it do a dance on spin ?....... is it a new machine .if so did you remove all the transit parts if not remove them ?
Mar 25, 2012 | Whirlpool Clothes Washer Tub Stablizer...
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
We have a duet sport ht, it seems to leaving greasy/oily spots on our clothes? any idea/cause? thanks
Be sure to use the quantity of wash powder recommended on the packet and not less. This will help keep the clothes AND machine clean.
Mar 23, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Inside of the dryer is cracking- huge holes!
the drum can be replaced but dont know if you want to pay for one they are probably expensive and 2nd if it is taking 2 to 3 times to dry clothes you have a vent problem which has caused the cracking of the drum probably cause so much heat build up in the machine your vent is stopped up and it isnt keeping the heat and moisture in the dryer which is a fire hazard please call a technician and please rate this
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washer keeps flashing f-21 and water coming out, I took some clothes out than started a new load a smaller one and now it will not even run. HELP!!
if you take the screws off of the foot plate and remove the foot plate on the back is a plastic bag where the codes can be found..... both washer and dryer are located there. good luck.
f21 long drain.
Aug 08, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
