Question about Kitchen Ranges
Miele 36" Hood DA249-1USA blower stopped working. Changed solenoid and Electronic Unit EPL753, but the blower is still not working. The lights work perfectly. The buttons work fine and you can hear the clicks each time the buttons are pressed. The motor spins freely and seems fine.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suggest a continuity check on the fan motor. Even if the solenoid, relay or controller were replaced and/or confirmed to be working and thus voltage is supplied to the terminals of the fan motor, the the motor (coil/windings) is open, then the fan will not spin.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 275 Answers
Might want to check that motor twice since you said blower stopped working..and consider some mechanical work done
Miele DA3480
First question. Has it done this since installation? If so, the installer has distorted the casing and the micro switch is not being operated by the slide. Easily fixed by installing it correctly. If it has just happened, then either a faulty micro switch or electronic control board. Just need to destall the unit to work on it but that is super easy. When re installing it, make sure the flue is attached correctly if one is used. Suggest two people unless you are an expert.
Nov 20, 2016 | Miele Kitchen Ranges
My Miele electric cooktop is completely out,
If the power is reaching the cooktop, can you see any power lights/leds lit on it? If there arent any their may be a fuse inside the cooktop that has blown, perhaps because of a fault. Unplug it turn the unit over and remove any covers on the electronics, use a bright light and have a good look for blackened (charcoal) marks on wiring or circuit boards. If there are any it, it has suffered a failure and the item that has failed may be the blackened part or any other, so the only way to be sure of fixing it is to replace all the electronics, hence it will be cheaper to buy a new cooker top.
Dec 14, 2013 | Miele 36 in. KM427 Electric Cooktop
Miele hood lights not working
Lamps blown or power electronic.
Oct 03, 2012 | Miele DA 249-4 Kitchen Hood
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
How long can the ducting be?
The ducting can be up to 50 feet in length.
Good Luck
Jul 30, 2010 | Miele DA5190W 36'' Wall Mount Chimney Hood...
My g595sc miele dishwasher after about 2-3 minutes of working come to stop with the "WATER INLET" light on. Please help.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Jan 22, 2010 | Dishwashers
Our MIELE TURBOTHERMIC shows a red indicator light on the topic of: drain/watersupply.when switched off and restarted, it evacuates the water succesfully and commences the cycle but then after two minutes,...
Dec 26, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Turning Lights Not Working
If you put a 2 element bulb in a single bulb elemet socket you would or could destroy the flasher unit. Especially if it is a electronic flasher try replaceing the flasher but get mechanicl flasher they last longer.
Jul 09, 2009 | 1998 Toyota Sienna
Vicking VIDV500 Kitchen Hood
steve...first, is the light working? If not, you may not have power. If so, turn off all power to the unit at the breaker. Remove the filter and see if the blower turns easily by hand. Yes...switch could be bad...no...motor bad.
Open up unit and using test light from the hardware store and motor plug disconnected...turn on fan and probe the motor feed wire for power. It may be the switch that's bad. This should tell you.
Dec 01, 2007 | Viking VEDV900 Kitchen Hood
Kitchen Ranges Logo
142 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
