Question about iLO 2600 Television
I can't get my iLO-2600 to completely work as a monitor.
I hooked up the cord, changed the settings according to the manual, but no icons or pages will show on the tv. The background shows and if I change background, the new background will appear. Also, when I test to see which computer is which a large number 2 will display on the tv and a number 1 on the laptop. One more thing, the screen saver will display when it kicks in. Please note that this was the first time I've tried to connect my tv to my laptop. This is NOT a problem of once having it working and then it suddenly stopped. Thank you so much for any advice or help! Ray
My remote has good batteries, and it doesn't turn the tv on. Can not think of the Modile that I was suppose to use, should of underlined it. Can you help me, so that I can pick the right code?
Posted on May 02, 2007
  • Alva Alexander May 02, 2007
    No this has to do with my tv Model-ITW3206
The TV will always show as screen number 2 because the laptop screen will be found first. I use mine as a monitor for my Desktop.. However, for the picture to show what your laptop does you have to clone your desktop. The button should be where your screen properties are located.
Posted on Apr 28, 2007
SOURCE:
Ilo 2600 HDTV manual
You would need a converter to make it work. Adapters won't work as the type of signal would need to be changes. Your best bet would be to purchase a DVD player that has outputs that work with the tv. Sorry.
Jul 07, 2016 | iLO 2600 Television
I have an ilo brand tv but i dont have a power cord for it, is there a universal cord i can use or do i have to order a specific cord for it? ilo 26hd is the model #.
You can use a universal power cord for it. Its the same power cord that you would use to plug in to say a computer or a newer age computer monitor.
Aug 12, 2011 | iLO 2600 Television
My dad gave me his flat screen tv. I didnt find a powercord for i
The plug is the same plug that powers your desktop pc or monitor. I do not know if Radio Shack carries it but you will find it on E-bay. Type "pc power cord" when searching. I know this because I have same unit and my PC power cord are interchageable. Hope this helps.
Avey
Jun 28, 2009 | iLO 2600 Television
My ilo says hd tv right on it, but i cant hook up hdmi cords to it
It may say HD on it but it may be a HD READY set, not a full HD FORMAT.
If it has componet inputs on it,( green, red, blue, and two audio inputs), you can use
them and still recieve HD. If it does not have componet or HDMI inputs on it , it is not a HD set
at all.
Hope this helps,
Skyassoc
Jun 16, 2009 | iLO 2600 Television
ILO-2600 tv need power cord
If you use a standard power cord for most radio's all I had to do was round of the edge and turn it into a figure 8 , works good or the plug fron norelco or remington razors work too
Apr 09, 2009 | iLO 2600 Television
Ilo 2600 need help to hook up cable & rca vcr
go in to the menu and then keep pressing it until u get to vedio 2 and try that
Apr 06, 2008 | iLO 2600 Television
26 ilo tv comes on but stuck in composite no functions on side works except for power switch
I would contact them on this
http://www.funai-corp.com/support/contact.aspx
in the manual see page 34 for testing the remote
http://www.funai-corp.com/6pdf/om/CIWL3206.pdf
Jan 26, 2008 | iLO 2600 Television
ILo Tv
I think this is the manual
see page 26
Jan 15, 2008 | iLO 2600 Television
Blue screen
set your dell desktop display for 1024x768 60 hz refresh.
right click on desktop/properties/1024x768
and then advanced/monitor for 60hz refresh
then connect to tv.
Dec 02, 2007 | iLO 2600 Television
ILO 26" LCD
The only thing that comes to mind is a similar, but not exact problem I recently had. If you're using cable try to change out the cord and/or the splitter with a higher grade. You can check to see if either of these is the problem by hooking the tv up to the original cord coming into the house. If the line disappears you know it's somewhere in the connections.
Apr 28, 2007 | iLO 2600 Television
Televison & Video Logo
93 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
